93 Civic EX Car idels funny then acts like it wants to die HELP
Old Dec 15, 2004 | 04:27 PM
93civic GED's Avatar
Default 93 Civic EX Car idels funny then acts like it wants to die HELP
when i starts it it idels hig lieka round 1500 for 2-6 seconds the jumps down to 800, then it starts to sputter and pop act like its going to die. Has exausht leak thou, piping is boke off before the muffler and i noticed a anti freeze leak.
any help please
thnx
joe
Old Dec 16, 2004 | 09:02 AM
any help?
Old Dec 17, 2004 | 11:23 AM
my room mate said he thought its was the distributor is this correct?
Old Dec 17, 2004 | 11:53 AM
AutoXer's Avatar
Default Re: 93 Civic EX Car idels funny then acts like it wants to die HELP (93civic GED)
Where is the antifreeze leaking from? You should fix any problems with the car to see if that helps with the idle first.
Most likely it'll be your IACV or you have a vac leak. To test for a leak, spray carb cleaner all around your vac lines, and if your idle jumps, there's your problem. If not, check your IACV, they go quite often and is the cause of a lot of idle problems.
Old Dec 17, 2004 | 01:00 PM
leaks from the house goign to radiator, the idels not the problem now the car wont even start so i dont know.
Old Dec 19, 2004 | 08:49 AM
well the idel isnt the problem now it wont start at all any help please.
Old Dec 20, 2004 | 03:46 PM
anyone else? is it the distributor?
joe
Old Dec 21, 2004 | 09:22 AM
AutoXer's Avatar
Default Re: (93civic GED)
What are the symptoms? Does it crank, does the fuel pump prime, is it getting spark?
Old Dec 21, 2004 | 04:31 PM
yes it cranks, yes fuel primes NO Spark so i think its hte dizzy.
joe
Old Dec 21, 2004 | 04:47 PM
dogfood's Avatar
Could also be something as simple as plug wires. If you have a spare set or can borrow some and throw em on. Also check your timing, you may need to adjust your distributor timing instead of just replacing it.
Old Dec 21, 2004 | 05:03 PM
its not the plug wires i just bought some new b4 it stoped. I think im gonna replace the coil that seems to be a common problem.
_kiid
May 7, 2009 03:01 AM
omg_jdm
Feb 26, 2009 07:23 PM
PhilMac
Sep 11, 2007 07:30 AM
ex_ricer
Apr 29, 2007 06:05 PM
spuddo01
Feb 1, 2006 01:37 PM
