Need help. 98 Civic no acceleration after 5000RPM
I have no idea what could be going on. I have a 199 Honda Civic with the 1.6 SOHC Vtec (D16Z6) from a 1995 Honda Civic in it. When i floor it, it will not go past 5000RPM, its like it hits a rev limit and the whole car just haults. And for a little while after that it is extremely slow and after a bit it will pick up. I have no clue what the problem could be. My check engine light is on but is reading code 41 which would be the primary O2 sensor, which i cant figure that out b/c the OBD2 requires 2 and OBD1 requires 1, and i just got the one replaced with a OEM Bosch replacement. I dont think the O2 sensor problem is causing this but not sure please help. Thank You.
broncoman74
Nov 25, 2007 06:42 AM
jcalar
Jun 28, 2006 09:39 PM
