New ITR owner - Quick question
Old Dec 15, 2004 | 04:03 PM
94si94cx's Avatar
Default New ITR owner - Quick question
I am going to pick up my ITR tomorrow. I've driven it a few dozens times (it's actually a good friend of mine's).
My question is, what suspension setup would give me a similar ride to the setup on my EG?
EG Suspension - Koni Yellows, Ground Control coilovers (425F/550R)
I wouldn't mind getting the same setup for the ITR, but would think the spring rates would be different because of the different weight.
Old Dec 15, 2004 | 04:08 PM
xmilanoredsix's Avatar
Default Re: New ITR owner - Quick question (94si94cx)
I think there are a few ITR guys that are running revalved KONI w/ 700f/600r.
I talked to 92TypeR for a little while last night and he strongly recommended ithe set-up to me.
Old Dec 15, 2004 | 04:11 PM
94si94cx's Avatar
Default Re: New ITR owner - Quick question (xmilanoredsix)
And people criticized me for going overboard on the spring rates!
I would think the jump in spring rate from the 2 cars would make a HUGE difference. I'm looking for something closer to my setup on the EG.
Old Dec 15, 2004 | 04:12 PM
He also tracks his car 1500 miles a year....
Old Dec 15, 2004 | 04:18 PM
Willard's Avatar
I would say that you should try it in stock form for a little while to see if you like it... then modify after some time/mileage.
Old Dec 15, 2004 | 04:21 PM
94si94cx's Avatar
Default Re: New ITR owner - Quick question (Willard)
I've had plenty of seat time on this ITR to know that the suspension could use some stiffening. It has Sportlines on it now (he just wanted a lower stance).
Old Dec 15, 2004 | 05:02 PM
uNF$@#!'s Avatar
he let you track his car alot?
Old Dec 15, 2004 | 05:09 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx &raquo;</TD></TR><TR><TD CLASS="quote">I've had plenty of seat time on this ITR to know that the suspension could use some stiffening.</TD></TR></TABLE>
Define "seat time" in this ITR? Have you tracked it yet? And if so what experience did/do you have?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx &raquo;</TD></TR><TR><TD CLASS="quote">It has Sportlines on it now (he just wanted a lower stance).</TD></TR></TABLE>
Did you get the stock springs as well?
And how fugged up are the stock shocks now after the drop?
If you liked the Koni/GC setup, you might want to contact CRXlee to help you decide a similar setup for the R.
Old Dec 15, 2004 | 05:17 PM
94si94cx's Avatar
Default Re: New ITR owner - Quick question (1GreyTeg)
Seat time = spirited driving (non-track)
I have the stock springs as well, and as far as I can tell the stock shocks are in good condition as well. But the car does have 95k miles on the chasis, so the shocks probably aren't perfect.
Old Dec 15, 2004 | 05:25 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx &raquo;</TD></TR><TR><TD CLASS="quote">Seat time = spirited driving (non-track)</TD></TR></TABLE>
Your definition would easily be misconstrued then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx &raquo;</TD></TR><TR><TD CLASS="quote">I have the stock springs as well, and as far as I can tell the stock shocks are in good condition as well. But the car does have 95k miles on the chasis, so the shocks probably aren't perfect.</TD></TR></TABLE>
If those are the original stock shocks I wouldn't be surprised if they're on their way out if they aren't already bouncing all over the place.
What about Koni's with Stock springs? I'm sure that would be a vast improvement to begin with.
BUT, What's your goal and budget? That's really the first 2 things you need to decide.
Here's a nifty link to some suspension topics and putting a post for the FAQ:
https://honda-tech.com/zerothread?id=1085106
Old Dec 15, 2004 | 05:44 PM
94si94cx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=1085106</TD></TR></TABLE>
My goal is to have a very firm nice planted ride without spending much more than $1000 on shocks, springs, and some sort of camber ajustment.
Old Dec 15, 2004 | 05:48 PM
KayOs's Avatar
My goal is to have a very firm nice planted ride without spending much more than $1000 on shocks, springs, and some sort of camber ajustment.</TD></TR></TABLE>
Why not just keep it stock? OEM suspension handles
Old Dec 15, 2004 | 06:00 PM
94si94cx's Avatar
Default Re: New ITR owner - Quick question (KayOs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">
Why not just keep it stock? OEM suspension handles </TD></TR></TABLE>
But is there not room for improvement?
Dynamix
16
Dec 11, 2002 02:48 PM
Dynamix
Aug 10, 2002 12:43 PM
bhcvc
Jan 23, 2002 09:44 AM
hondura
Dec 12, 2001 06:18 PM
