Honda top engine cleaner?
Old Jan 3, 2002 | 09:25 PM
smokin rubber's Avatar
Default Honda top engine cleaner?
http://www.manhonda.com/store/honda/...TOKEN=88046812
Has anybody used this product? Seems like it might be worth a try
Old Jan 3, 2002 | 09:40 PM
martini's Avatar
Default Re: Honda top engine cleaner? (smokin rubber)
Honestly, just suck some Auto Tranny Fluid into your intake. I'm sure it's about the same thing.
People have used ATF to clean thier combustion chambers (piston or rotary) for decades.
Old Jan 4, 2002 | 10:55 AM
rtype11's Avatar
Default Re: Honda top engine cleaner? (martini)
are you smoking crack the atf goes in with the oil. or put one cap full in each spark plug hole. this way you clean combustion chamber and motor block.
Old Jan 4, 2002 | 11:22 AM
speedymon's Avatar
Default Re: Honda top engine cleaner? (rtype11)
would this make you car susceptable (spelling?)to leaks?
Old Jan 4, 2002 | 12:19 PM
How would anything in the oil clean the combustion chamber? ATF ,uuu I have an manual, and this stuff is less than four bucks.
Old Jan 4, 2002 | 12:46 PM
chi1874436's Avatar
I just used some carbon cleaner from a local store. I had to place it in through the intake manifold and continue to rev up the motor until the cleaning process was finished. I just had to do it in the middle of nowhere and the carbon just smokes right out thru the exhaust. SMOKE EVERWHERE.
Old Jan 4, 2002 | 08:00 PM
martini's Avatar
Default Re: Honda top engine cleaner? (chi1874436)
Good point. One thing to remember, do this stuff at night, because otherwise, your neighbors will call the fire department because of all the smoke...there will be a LOT.
And yes, it's $4 plus shipping..but you'll find ATF for cheaper than that. Whatever..if you feel more comfortable buying something that says it's made for what you want to do, then go for it.
[Modified by martini, 9:02 PM 1/4/2002]
Old Jan 4, 2002 | 09:42 PM
How much would you use at a time. Do I just pull the inttake tube off or put the valve cover breather hose in the bottle?
Old Jan 4, 2002 | 10:15 PM
RyanR's Avatar
It DOES NOT go into your oil. Just pull the line off the check valve that is between the intake manifold and your brake booster. Stick the hose into the bottle and have someone rev the engine at 3K and hold it. The engine will suck up the ATF and do the rest. But like martini said, make sure it's dark or no one is around. You'll get tons of smoke out the exhaust. All you really need to use is about a 1/4 to 1/2 quart of ATF.
Old Jan 5, 2002 | 07:30 AM
nfn15037's Avatar
Default Re: Honda top engine cleaner? (97TypeR_9)
Is this ok for that cat? Im thinking its not, so we should probably disconnect the cat then do it? I think ill do it right in my apartment parking lot, hehe, they hate my car anyways LOL.
Old Jan 5, 2002 | 11:01 AM
thanks for all the replies , time to smoke out the neighborhood.
D3U1LT
14
Jul 21, 2006 01:28 PM
Red_EM1
Jul 18, 2004 09:21 PM
B2FiNiTY
Feb 10, 2003 10:59 PM
Guam_CiviC619
Aug 27, 2002 10:44 AM
h46it
May 20, 2002 07:19 AM
