CEL??
Old Dec 14, 2004 | 07:10 PM
Tim.'s Avatar
Default CEL??
00 civic Si
my CEL came on ramdomly while slowing down for a stoplight. as the CEL came on the idle jumped up to 1500 rpm. the idle will drop down to normal level when i take it out of gear, then will go up to 1500 and will bounce a little bit between about 1400 and 1500. why would this happen?
any help is appreciated
i'm thinking at might be something to do with injectors or something i'm going to try seafoaming it tomorrow. i have never seafoamed before.
thanks
Old Dec 14, 2004 | 07:15 PM
slow94coupe's Avatar
Default Re: CEL?? (spoon0313)
why not find out what the check engine light is for before you waster your money on other methods? sea foam sucks in my opinion. auto or manual?
Old Dec 14, 2004 | 07:17 PM
civictildeath's Avatar
Default Re: CEL?? (slow94coupe)
ya definately find out what code your throwin first
Old Dec 14, 2004 | 07:35 PM
Civic92Turbo's Avatar
check cel
https://honda-tech.com/zerothread?id=682412
Old Dec 14, 2004 | 08:00 PM
Tim.'s Avatar
Default Re: CEL??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow94coupe &raquo;</TD></TR><TR><TD CLASS="quote">why not find out what the check engine light is for before you waster your money on other methods? sea foam sucks in my opinion. auto or manual?</TD></TR></TABLE>
obviously a manual. waste $5? damnit!
i know i should check the code. i'm lazy. ill do it tomorrow.
Old Dec 15, 2004 | 06:43 AM
Tim.'s Avatar
Default Re:
threw code 14. idle air control valve
not sure what this means. heeellllppp
Old Dec 15, 2004 | 07:03 AM
Tim.'s Avatar
up
Old Dec 15, 2004 | 07:12 AM
Kamin's Avatar
Default Re: (spoon0313)
it means there is a problem with your idle air control valve.
check the connector, clean the valve itself. im pretty sure its located on the bottom of the throttle body.
Old Dec 15, 2004 | 07:14 AM
Tim.'s Avatar
Default Re: (Kamin)
thanks dood. bottom of the throttle body.....
Old Dec 15, 2004 | 09:46 AM
Tim.'s Avatar
i didn't find it on the bottom of the throttle body..
where exaclty is the valve? and, how does this affect how my car runs. any precautions i should take? or drive as normal?
thanks
Old Dec 15, 2004 | 10:16 AM
SOHC_Brian's Avatar
its behind the intake manifold. can't help u fix it cause i'm having the same problems and been trying to tackle it for the past 3 days
Old Dec 15, 2004 | 01:19 PM
Tim.'s Avatar
werd.
fixed.
took it off and cleaned it out with alcohol and a q-tip.
no more CEL. the small screen thing inside was gooped up.
perfect idle now.
19cIvIc94
Jan 21, 2009 10:31 AM
TylerC
Aug 18, 2005 10:28 PM
game over
Feb 19, 2005 06:15 PM
Bruce_Willis
Dec 10, 2004 10:37 AM
BlkGSR
Jun 18, 2003 07:11 PM
