CEL??
CEL??
00 civic Si
my CEL came on ramdomly while slowing down for a stoplight. as the CEL came on the idle jumped up to 1500 rpm. the idle will drop down to normal level when i take it out of gear, then will go up to 1500 and will bounce a little bit between about 1400 and 1500. why would this happen?
any help is appreciated
i'm thinking at might be something to do with injectors or something i'm going to try seafoaming it tomorrow. i have never seafoamed before.
thanks
thanks
Re: CEL??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow94coupe »</TD></TR><TR><TD CLASS="quote">why not find out what the check engine light is for before you waster your money on other methods? sea foam sucks in my opinion. auto or manual?</TD></TR></TABLE>
obviously a manual. waste $5? damnit!
i know i should check the code. i'm lazy. ill do it tomorrow.
Re: (spoon0313)
it means there is a problem with your idle air control valve.
check the connector, clean the valve itself. im pretty sure its located on the bottom of the throttle body.
i didn't find it on the bottom of the throttle body..
where exaclty is the valve? and, how does this affect how my car runs. any precautions i should take? or drive as normal?
thanks
thanks
