Sparco Harnesses...install
Old Dec 14, 2004 | 04:00 PM
ELAMINT5's Avatar
Default Sparco Harnesses...install
I have Recaro seats and just got an great deal on two new Sparco 4 point harnesses. I was wondering how to install these without drilling holes into the car. Is there a correct way to do so? Now on the end of the belts there are metal hooks for the bolt to screw the harnesses down. I currectly have two bottom ones bolted to where the seat bolts to the floor and the top two bolted to the rear upper strut tower brace. What I have works but if there is an better way I can not think of it. I am ready so FLAME AWAY GUYS! It seems for every 10 smartasses there is 2 good on here.
would a role bar help?.. that is what I seen when searching. what is a role bar?
Old Dec 14, 2004 | 04:12 PM
essex's Avatar
Default Re: Sparco Harnesses...install (ELAMINT5)
You shouldn't use a harness without a rollbar. Because if you car rolls over and you are strapped in with your harness you head will be smashed by the roof.
Here is a pic of someones roll bar you can see how the harness wrap around the bar.
https://honda-tech.com/zerothread?id=1077968
heres another pic off a roll bar(the black tubes)
https://honda-tech.com/zerothread?id=778288
Modified by essex at 1:25 AM 12/15/2004
Old Dec 14, 2004 | 04:19 PM
ELAMINT5's Avatar
Default Re: Sparco Harnesses...install (essex)
is there a difference in a rollgage and a roll bar? is the bar just the on that goes behind the seat? would I have to cut the metal things off the end of the harness to get it to wrap around it right?
Old Dec 14, 2004 | 04:27 PM
Drives EG's Avatar
the one that goes behind the seat is called a harness bar but most roll cages have them. a roll bar usually just goes around the roof of the car i think. you really should wrap it around the bar somehow, otherwise you could brake your spine if the harness pulls down too far on your shoulders. this is not good.
Old Dec 14, 2004 | 04:29 PM
essex's Avatar
roll bar is behind the seats .......I'm not sure about cutting the ends off but that makes sense.
You can buy a premade roll bar from a company call AutoPower or you can have some one make you a custom one. If you post up in the welding forum lots of those guys can make custom roll bars.
Old Dec 14, 2004 | 04:32 PM
ELAMINT5's Avatar
damn I had not idea I could break my spine. i will look into having one made
Old Dec 14, 2004 | 06:42 PM
Los.'s Avatar
i have my harness wrapped really tight around my rollbar, works pretty decent nice n snug in my sparco sprint ill try to post pics
Old Dec 15, 2004 | 05:36 AM
ELAMINT5's Avatar
Default Re: Sparco Harnesses...install (crxkid88Sir)
post or email if you would. djohnson@auffenberg.com THANKS GUYS'n'GALS
Old Dec 15, 2004 | 05:48 AM
jhota's Avatar
http://www.simpsonraceproducts..._info
basic safety info on harness installation
meheartmycivic
Sep 2, 2009 09:46 PM
streetsold6teeny8
30
Aug 29, 2009 02:49 PM
turbo-crx
Welding / Fabrication
Feb 28, 2009 05:07 PM
eskimo_usd
Sep 9, 2005 08:41 AM
Outsane
Oct 31, 2003 10:05 AM
