Mini Me or Turbo - Vote!
Old Dec 14, 2004 | 11:32 AM
LSVTEC 91 Civic's Avatar
Banned
Default Mini Me or Turbo - Vote!
Okay, I'm the proud owner of a 89 DX with only 60k miles, but there is one problem with this car. Its TOO slow. Yes, it is only my daily driver.. but with the AC on, it goes like a snail... and good luck passing on the highway - too dangerous. So, I've been doing some thinking..
If I go Mini-me, I probably won't gain much power, and it will be a pain in the ***. ECU swap, MPFI conversion, Swapping head... I'd be taking apart a perfectly good engine and I don't really want to do that for a torqueless SOHC VTEC head.
Now, I ran across this. http://www.homemadeturbo.com/turbo_projects/d15b2/
a DPFI Home made turbo. Looks easy, cheap, and I think i'll probably make more power than I would with a Mini-me.
Edit: If I boost i'll be doing MPFI, but will be keeping the head and everything else.
Vote based on cost, power gains, and relibility.
How would my low mileage D15 handle a small RHB5 turbo? This turbo is stock @7psi, but could I turn it down to 5psi if I plan on throwing it on my engine?
Modified by LSVTEC 91 Civic at 9:31 PM 12/14/2004
Old Dec 14, 2004 | 12:17 PM
eumoria's Avatar
Default Re: Mini Me or Turbo - Vote! (LSVTEC 91 Civic)
Do it, woo! I think i'd be worth swapping the MPFI Mani and Si ECU in there, though. The difference amount you get out of a DPFI Turbo setup and a MPFI Turbo Setup on the same engine is absurd. It's worth the little extra work and $$
If you have all the turbo parts lying around, though, hook it up! Should be a lot better than stock B2.
Old Dec 14, 2004 | 12:23 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Mini Me or Turbo - Vote! (eumoria)
i've heard about that DPI turbo and almost did it to my b1 i just dont feel it would be reliable.
MPFI or mini me then boosting or swaping will be alot easier and safer.
Old Dec 14, 2004 | 12:48 PM
TxTuner
Guest
Posts: n/a
boost that beauty yo!!!
Old Dec 14, 2004 | 01:28 PM
mellon's Avatar
Default Re: Mini Me or Turbo - Vote! (TxTuner)
Where's the option for both :D
Old Dec 14, 2004 | 02:35 PM
CRX_1.8T's Avatar
I'm gonna have to say turbo as well; at around 5 psi, that would make your car good enough to pass people, get onto on-ramps, etc safely.
Old Dec 14, 2004 | 02:38 PM
Banned
Default Re: Mini Me or Turbo - Vote! (mellon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mellon &raquo;</TD></TR><TR><TD CLASS="quote">Where's the option for both :D</TD></TR></TABLE>
I'd rather not pull the head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T &raquo;</TD></TR><TR><TD CLASS="quote">I'm gonna have to say turbo as well; at around 5 psi, that would make your car good enough to pass people, get onto on-ramps, etc safely. </TD></TR></TABLE>
How reliable with 5psi be on my stock D15.. Keep in mind it only has 60k on it.. and I want it to last a long time.
Old Dec 14, 2004 | 02:42 PM
BauleyCivic's Avatar
Risky Business
Thats what I did...but IMHO Turbo &gt; Mini-Me
Mini-me felt good, but the power that the turbo added blew me away
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
How reliable with 5psi be on my stock D15.. Keep in mind it only has 60k on it.. and I want it to last a long time.</TD></TR></TABLE>
I'm at 6psi on a 180,000mi stock D15B7 block
Old Dec 14, 2004 | 02:47 PM
CRX_1.8T's Avatar
I think that if you get some engine management (like Z-Dyne's OBD-0) and get everything tuned, not for crazy performance but for good city driving and longetivity, I think that you would have a reliable turbo car on your hands.
Old Dec 14, 2004 | 02:49 PM
RIPracing's Avatar
Default Re: (CRX_1.8T)
If you got the money go with the turbo!!!
Old Dec 14, 2004 | 02:52 PM
Banned
Default Re: (RIPracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIPracing &raquo;</TD></TR><TR><TD CLASS="quote">If you got the money go with the turbo!!!</TD></TR></TABLE>
It'll only cost a few hundred bucks... I'd be using a probe turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T &raquo;</TD></TR><TR><TD CLASS="quote">I think that if you get some engine management (like Z-Dyne's OBD-0) and get everything tuned, not for crazy performance but for good city driving and longetivity, I think that you would have a reliable turbo car on your hands.</TD></TR></TABLE>
Sounds good.. but is that ECU necessary for relibility? ECU Might be a problem also, car is auto. What if I were to tune 5lbs with an FPR/Wideband o2..
Old Dec 14, 2004 | 09:48 PM
trustnoone7935's Avatar
Do both dude, screw it ur already going mpfi might as well pull the head and go v-tec too.
Old Dec 14, 2004 | 10:16 PM
turboZChatch's Avatar
Default Re: Mini Me or Turbo - Vote! (CRX_1.8T)
mpfi conversion with a vtec head and the little turbo on 5psi for a little more hp plus a little more fun
Old Dec 15, 2004 | 01:40 AM
Creepshow S60's Avatar
Is it just me, or does anybody else see the irony in turbocharging a car so you can pass people on the highway?
Old Dec 15, 2004 | 05:32 AM
Proglow3's Avatar
Get the D-series turbo...that way if you do end up blowing the engine you can up grade to a larger D-series and still use your turbo kit. D-series are pretty cheep, that's why I would do it.
Old Dec 15, 2004 | 06:03 AM
slowpokesi's Avatar
Default Re: Mini Me or Turbo - Vote! (Proglow3)
i wouldnt waiste your money on a dx AUTOMATIC.
if you want to pass people on the highway then convert to manual!
i wouldnt turbo a automatic honda,
Old Dec 15, 2004 | 09:24 AM
Recluse03's Avatar
Default Re: Mini Me or Turbo - Vote! (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt waiste your money on a dx AUTOMATIC.
i wouldnt turbo a automatic honda, </TD></TR></TABLE>
ShortbusEK
Apr 22, 2008 06:05 AM
compwc18
May 25, 2005 10:47 PM
ekzrated
Feb 16, 2005 07:28 AM
preludeguy
Apr 12, 2003 08:43 AM
Vp Special K
May 19, 2002 12:15 PM
