oil catch can
Old Jan 3, 2002 | 11:06 AM
rainforest's Avatar
Default oil catch can
i have never made one the only question i have is do i have to tee the existing pcv in with the one from the catch can to the intake manifold?
Old Jan 3, 2002 | 11:11 AM
Spade's Avatar
Default Re: oil catch can (rainforest)
Not really following but, the line going from the PCV should have the catch can in it. In other words
PCV------Catch can------Intake. Or PCV------Catch can w/breather filter on top (not smog legal).
[Modified by Spade, 12:11 PM 1/3/2002]
Old Jan 3, 2002 | 11:35 AM
VaporTrail's Avatar
New User
there is a lot of confusion on how this works, but it's not that difficult.
You have the oil seperator on the back of the block. The line normally runs from there, to the PCV valve, to the manifold. To add a catch can, you run the line from the oil seperator to the catch can, to the PCV, to the intake.
Old Jan 3, 2002 | 11:50 AM
rainforest's Avatar
Default Re: oil catch can (VaporTrail)
so you bypass the pcv on the intake manifold between the runners john?
so its this oil seperator to the can then from a pcv on the can to the intake manifold.
[Modified by rainforest, 8:51 PM 1/3/2002]
Old Jan 3, 2002 | 11:56 AM
brcivic411's Avatar
what kind of car do u have? you don't want to bypass the pcv valve @ all. like what was posted, you want to keep the pcv in line with the catch can and intake manifold
Old Jan 3, 2002 | 07:11 PM
rainforest's Avatar
Default Re: oil catch can (brcivic411)
well then there is two pcv's one in the catch can to the intake manifold and one from the oil seperator to the intake manifold. there would be two existing pcv's
so john do i use a pcv on the intake manifold (between the runners) when routing it acually to the intake manifold, or from a pcv to the intake manifold.
[Modified by rainforest, 5:03 AM 1/4/2002]
Old Jan 3, 2002 | 07:58 PM
rainforest's Avatar
does any one have pics of a catch can installed on a b series motor.[Modified by rainforest, 5:00 AM 1/4/2002]
[Modified by rainforest, 5:01 AM 1/4/2002]
[Modified by rainforest, 5:34 AM 1/4/2002]
Old Jan 3, 2002 | 08:49 PM
rainforest's Avatar
ok i got it now
[Modified by rainforest, 6:16 AM 1/4/2002]
[Modified by rainforest, 6:17 AM 1/4/2002]
[Modified by rainforest, 8:16 AM 1/4/2002]
Old Jan 4, 2002 | 09:10 AM
BSQ's Avatar
BSQ
Here is a picture of my oil catch can installed in my '94 Integra GS-R.
Larger picture: http://www.imagestation.com/picture/...5.jpg.orig.jpg
Old Jan 4, 2002 | 09:54 AM
BSQ's Avatar
BSQ
Default Re: oil catch can (Teken)
Bret,
You should just give him the link and the instructions on how to build one from your site... That would benefit more people I feel...
Teken,
Good idea!!! Here is the link to my webpage: http://www.geocities.com/bretq/DIY_O...tructions.html
Old Jan 4, 2002 | 01:34 PM
Flamenco-T's Avatar
while we're on the subject..what about on turbo cars ?
John, I am hoping you can help me with this...
should I install mine fromt the breather hose on the valve cover - catch can- intake piping before turbo..
or
the PCV valve - catch can - intake manifold ?
thanks
stan
PS: I am getting like a million answers, so it kinda confuse me even more...
Old Jan 4, 2002 | 04:24 PM
Bombino's Avatar
New User
Default Re: oil catch can (Flamenco-T)
stan.. ideally.. you would want to have 2 catch cans, one hooked up inline with the PCV and intake manifold, and one inline with the valve cover and intake pipe.
thats what i have anyways.
keep in mind the more area that you open up with catch cans, the more oil psi you're losing.. I dont feel i need it, but im ****, so ill prolly be shimming my oil pump very soon.
Tony
Old Jan 4, 2002 | 06:23 PM
rainforest's Avatar
Default Re: oil catch can (Bombino)
i allready made it and it works fine.
Old Jan 5, 2002 | 07:43 AM
earl's Avatar
How would an open breather effect oil pressure?
NA JDM GSR
Oct 17, 2006 08:31 PM
bootlegtrader
Sep 19, 2005 11:46 AM
user 98292739
Apr 27, 2005 01:26 PM
xtrafastcivic
Jun 15, 2002 02:31 AM
xtrafastcivic
Mar 25, 2002 01:22 PM
