HF adapter?
Old Dec 12, 2004 | 07:58 PM
LostCRX's Avatar
Default HF adapter?
I'm putting a homemade turbo kit for my lil bro's civic. Does anybody know what a HF adapter this guy is talking about?
http://cgi.ebay.com/ebaymotors...%3AIT
Old Dec 12, 2004 | 08:06 PM
mrspeaker's Avatar
Default Re: HF adapter? (LostCRX)
I see he says its not included..
Its an adapter plate..It allows the turbo to be bolted to the manifold..
On on side of the plate it is made to fit the manifold and on the other its made to fit the turbo...In this case you need a t3/t4 4-bolt adapter plate..I've seen them go for around $30-$40 off ebay..And they're always for on homemadeturbo.com in the classifieds..
Ive seen he's welded on the pipe for an external wastegate..Dont know if his welding skills are that good..
And delta wastegates are know to have boost creep..They've blown up alot of motors from overboosting..
That turbo was originally internal wastegate so I'm geussing he welded the wastegate flapper shut..Make sure how he did it before purchasing
Modified by Mrspeaker at 12:34 AM 12/13/2004
Old Dec 13, 2004 | 12:54 PM
LostCRX's Avatar
Default Re: HF adapter? (Mrspeaker)
cool, thanks.
He said it was professionally welded, but since the manifold is cast, there's always a chance of failure.
I think i'm gonna get it.
Old Dec 13, 2004 | 01:46 PM
7PSI CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostCRX &raquo;</TD></TR><TR><TD CLASS="quote">Does anybody know what a HF adapter this guy is talking about?
One side bolts to the CRX HF Exhaust Manifold
The other side bolts to the turbo
Add in the proper studs
(Made by yours truly)
Old Dec 13, 2004 | 04:01 PM
LostCRX's Avatar
wow, that's even better.
Old Dec 13, 2004 | 09:28 PM
doublethink's Avatar
Default Re: (LostCRX)
sick!
Old Dec 14, 2004 | 01:35 AM
7PSI CRX's Avatar
Aren't there cheap turbo manifolds available?
(DON'T BUY FROM DROPSHOP)
If so, I would go with that. Looks much nicer to me.
Personaly I think the "adaptor plate" is sorta ghetto. But I know a lot of people who use 'em.
Old Dec 14, 2004 | 12:56 PM
LostCRX's Avatar
I guess you can say homemade is ghetto, but it works right?
jpo20
Mar 23, 2009 01:27 PM
sasinorm01
Mar 14, 2008 08:14 PM
Jdm_Eg686
Dec 7, 2006 12:19 PM
sinfulj32
Nov 14, 2004 06:53 AM
4drEF
Mar 16, 2004 06:07 AM
