Check Engine Light, Code P1457
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">Make sure your gas cap is on tight.
code 1456 would be a loose gas cap. 1457 is for the canister system not the tank system
</TD></TR></TABLE>code 1456 would be a loose gas cap. 1457 is for the canister system not the tank system
https://honda-tech.com/zerothread?id=748876
Look about 2/3 of the way down for my post about what to check out...
Ah yes, a northern car. All the corrosion will cause this, it's one of the valves on the canister, the vent shut valve I believe. If you've got under 80k miles, it's probably under the federal emmissions warranty. I'd give the dealer a quick call to check.
Thanks for pointing out the gas cap is p1456.
