Engine Missing
Old Dec 11, 2004 | 07:33 PM
Blueallie's Avatar
Default Engine Missing
Car is a 91 crx si w/210000 miles. I just changed the plugs, cap,rotor, and igniter.
It idles at about 1100 rpm and its missing. Anything over idle it's fine. What are some things that could be causing it to miss at idle?
Thanks in advance.
Old Dec 11, 2004 | 07:40 PM
RedlinedVTEC's Avatar
Default Re: Engine Missing (Blueallie)
Eh got the plug wires mixed up? 1-3-4-2 starting at bottom left going clockwise is the firing order.
Old Dec 11, 2004 | 07:45 PM
Blueallie's Avatar
Default Re: Engine Missing (RedlinedVTEC)
Nah, got that right otherwise it would miss throughout the rpm range instead of just idle.
Old Dec 11, 2004 | 07:50 PM
Lol how'd I miss this one... must have been my long day at the shop. What's your ignition timing at? I bet that's your problem. If you don't have a timing light just loosen the 3 12mm bolts a little (just enough so you can rotate the dist.) start it up and then rotate the distributor until the idle evens out.
Old Dec 11, 2004 | 07:59 PM
Blueallie's Avatar
Whats base timing set at? I'll go get a timing light in the morning. Lol wish I had a shop
Old Dec 11, 2004 | 08:21 PM
16 degrees below top dead center. Here's the only pic I could find online to show you:
in fact there's a whole write up here: http://www.c-speedracing.com/h...g.php. And yes sohc timing is the same as dohc.
Old Dec 11, 2004 | 09:16 PM
Blueallie's Avatar
So if i had an I/H/E would base timing be the the best or would advancing it alittle be better?
thanks for the link
Thanks,
Gary
jdmark1
Mar 14, 2018 10:21 AM
NoVALude
Nov 20, 2006 11:02 AM
bassysingh
Oct 17, 2005 10:02 AM
keebler65
Oct 2, 2003 09:14 PM
Civic89
Aug 8, 2002 01:48 PM
