Sprung clutch hub or solid?
Any of you R guys ever used a solid hub in your R before? If so, is it annoying to drive on the street or in grid-lock traffic? I'll be getting a new clutch soon & just wanted some info. Thanks!
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i have driven on solid hub discs, and they are not that bad. but, if you goof, like say misshift, you not only wreck your motor but can quite possibly damage the trans as well. if you get a good quality sprung disc, you will not have any problems.
Thanks for all the opinions guys. That'll help me descide better. The only thing is my R isn't a daily driver & I really liked the solid engagement of a friends clutch in his 99 Si. Just a few bolt-ons & it would bark the tires going into 3rd gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR »</TD></TR><TR><TD CLASS="quote"> I really liked the solid engagement of a friends clutch in his 99 Si. Just a few bolt-ons & it would bark the tires going into 3rd gear. </TD></TR></TABLE>
Thats what, we all aim to accomplish.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR »</TD></TR><TR><TD CLASS="quote">Thanks for all the opinions guys. That'll help me descide better. The only thing is my R isn't a daily driver & I really liked the solid engagement of a friends clutch in his 99 Si. Just a few bolt-ons & it would bark the tires going into 3rd gear. </TD></TR></TABLE>
I don't see that being something to work up to... even with my bad driving I spin 4th gear... I don't get it?
Why would anyone want to spin tires except for showing off at Expos?
And the unneeded stress into the tranny is just not smart. Unless you have plenty of money for rebuilds and replacements...
solid hub can lead to more wear on everything.. i had full street disk with solid hub, it grabbed no matter how i shifted.. this is not 4-6puck, its full street disk.. and it was completely driveable, yet unnecessary..
my current setup is oem clutch/oem release beraing/8.5 lbs flywheel and 1800lbs pressure plate (stock is 1500lbs) at ~ 260whp... 20k some miles.. -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">
And the unneeded stress into the tranny is just not smart. Unless you have plenty of money for rebuilds and replacements... </TD></TR></TABLE>Oh, I totally agree. It was just the point for making on the vast difference of the OEM clutch compaired to the aftermaket one. I guess it was so much a noticeable difference cause my clutch is starting to slip when I make a harsh demand on it.
I have an ACT 6 puck unsprung with Heavy Duty pressure plate and it's not bad at all even in traffic. It's not that I'm used to it either cause when I first put it in I remember saying to myself "that's it??"
I was expecting alot worse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999all_motoR_teg »</TD></TR><TR><TD CLASS="quote">I have an ACT 6 puck unsprung with Heavy Duty pressure plate and it's not bad at all even in traffic. It's not that I'm used to it either cause when I first put it in I remember saying to myself "that's it??"
I was expecting alot worse.</TD></TR></TABLE>
And the responses from everyone who drives my car with the ACT XT-SS is what are you nuts??? then they stall many times
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda »</TD></TR><TR><TD CLASS="quote">I am running the Action 1ms, sprung disk with heavy duty pressure plate. It is holding like a ****
I've got the 1MD. I'm not a fan. Sucky engagement (howling sound and shuddering), and it's slipped a couple of times at HPDE's (hard shifts into 4th/5th, sometimes it just didn't grab.)
Don't know how much is the clutch, compound, or unsprung hub.
Unsprung can be more reliable, if you're worried about snapping springs on the clutch.
-Chris
</TD></TR></TABLE>I've got the 1MD. I'm not a fan. Sucky engagement (howling sound and shuddering), and it's slipped a couple of times at HPDE's (hard shifts into 4th/5th, sometimes it just didn't grab.)
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">I've got the 1MD. I'm not a fan. Sucky engagement (howling sound and shuddering), and it's slipped a couple of times at HPDE's (hard shifts into 4th/5th, sometimes it just didn't grab.)
-Chris</TD></TR></TABLE>
.....you need the 2md or greater. You're making too much tq for the 1md.....
Well, my stock clutch plate recently took a dump on me, broke off a piece of the metal plate around one of the springs, and it also had fractured at another spring as well. Kinda sucks as there was still some meat on the clutch but that's life i guess. Had this been a solid disk this failure would not have occurred. Next clutch for me will be an ATS metal clutch/flywheel combo and this one has a solid hub. Time will tell how it works out.
I was expecting alot worse.</TD></TR></TABLE>Thanks guy for some 1st hand info! Thanks.
Nope, not a daily.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wht-Blk dc2 »</TD></TR><TR><TD CLASS="quote">if it's a daily driven car, there would absolutely be no point in getting a solid hub clutch. </TD></TR></TABLE>
