my car died... anyone here a real tech?? hollar in...
Old Dec 10, 2004 | 04:08 PM
boi_si's Avatar
Default my car died... anyone here a real tech?? hollar in...
car died while idling. engine has no spark. jus swap dist with a friend. no start. no fuel pump sound from rear (used to hear this). swap fuel pump. no start. what else?
located in sac. anyone willing to come help?
Old Dec 10, 2004 | 04:24 PM
$300lude's Avatar
Default Re: my car died... anyone here a real tech?? hollar in... (boi_si)
try the main relay
Old Dec 10, 2004 | 04:27 PM
Pioneer162's Avatar
Default Re: my car died... anyone here a real tech?? hollar in... ($300lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $300lude &raquo;</TD></TR><TR><TD CLASS="quote">try the main relay</TD></TR></TABLE>
fuses
Old Dec 10, 2004 | 04:38 PM
Archidictus's Avatar
Unceasing Measure
Default Re: my car died... anyone here a real tech?? hollar in... (Pioneer162)
Main Relay.
Old Dec 10, 2004 | 04:42 PM
cxSHOE's Avatar
main relay x3 just above your hood release ( &lt;&lt;&lt;on92-95 civics 96+&gt;&gt;&gt; to the right of the glove box which needs to come off.). that square thing .
Old Dec 10, 2004 | 04:52 PM
Turbogixxer's Avatar
Default Re: my car died... anyone here a real tech?? hollar in... (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">main relay x3 just above your hood release. that square thing .</TD></TR></TABLE>
EG
EK
That makes it alittle easier, eh?
Old Dec 10, 2004 | 10:33 PM
boi_si's Avatar
u guys mean swap the pgm fi main relay with an EG friend?
it cranks but no start.
B18C in EG... i use to hear a sound from the fuel pump but since it died i dont hear it anymore. even with the swapped fuel pump.
Old Dec 10, 2004 | 11:34 PM
bigboostersx's Avatar
Check power at the fuel pump, run a ground wire to the battery ground then, with a manual find the power wire with for fuel pump and connect it to the positive terminal on your battery and see if it starts and runs, then you will know that you have possible fuse, relay, or wire proublem
Old Dec 11, 2004 | 01:10 AM
boi_si's Avatar
Default Re: (bigboostersx)
can it be a possible ECU problem? j/w... since i have jdm P72 ecu. which i doubt. never...
Old Dec 11, 2004 | 03:16 AM
Default Re: (boi_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boi_si &raquo;</TD></TR><TR><TD CLASS="quote">can it be a possible ECU problem? j/w... since i have jdm P72 ecu. which i doubt. never...</TD></TR></TABLE>
Stop guessing. Buy/borrow a test light and check your fuses, power to the fuel pump, main relay. Test lights are like $5-$20
Old Dec 11, 2004 | 05:39 AM
r_Senik's Avatar
Default Re: (turbogixxer)
main relay or ignition switch
Old Dec 11, 2004 | 06:57 AM
McNizzle's Avatar
Default Re: (r_Senik)
im having the same problem as you and then i noticed that my ACG (S) 15amp fuse keeps blowing. i havent found out whats making it blow yet but you should check that fuse. its right next to the SRS fuse underneath the drivers side dash keep us updated
Old Dec 11, 2004 | 10:29 AM
The Internet Tough Guy's Avatar
Default Re: (Chris M)
check your grounds.
bad ground = crazy ****
Old Dec 11, 2004 | 11:12 AM
TurboEH2's Avatar
Default Re: (jwn7)
i agree with these, check main relay (always a honda killer), fuses, grounds
Old Dec 11, 2004 | 11:18 AM
rob...'s Avatar
Default Re: (LSturboEH2)
main relay or ecu
Old Dec 11, 2004 | 11:21 AM
92_civic's Avatar
Default Re: (baseballinmyass)
even simplier, in case you don't have a test light, crack loose the 17mm bolt on the fuel filter and see if you have fuel pressure
Old Dec 11, 2004 | 11:23 AM
Jimmy's Avatar
Global Moderator
Heres my PGM-FI main relay write up:
HOW TO: Fix your PGM-FI Main Relay
Old Dec 14, 2004 | 03:47 PM
boi_si's Avatar
Default Re: (Jimmy)
thanks H-T... it was the main relay... and also my distributor too...
i wonder how both went at the same time..
93 EG
Oct 14, 2007 01:57 PM
flipsyde
Apr 28, 2007 09:43 PM
Used2beAb16
May 25, 2005 05:23 AM
markvqwerty
Aug 27, 2004 08:52 AM
drew2
Apr 29, 2004 05:02 AM
