main relay??
main relay??
okay im not good with electrical... but is there a way to check the main relay if its good, bad, or going bad. maybe by hooking a voltmeter to it or somthing and checking the numbers, amperage, or whatever its called in the electrician world.
Re: main relay?? (flipsyde)
if you drop me a e mail i will send you the info since it is in pdf form.
dinotapia@sbcglobal.net
Re: main relay?? (dtapia)
the main relay controls your fuel pump. you should be able to hear the fuel pump prime and you should hear the main relay click aswell. here the a site that is really informative.
http://techauto.tripod.com/mainrelay.htm
good luck.
good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtapia »</TD></TR><TR><TD CLASS="quote">if you drop me a e mail i will send you the info since it is in pdf form.
dinotapia@sbcglobal.net</TD></TR></TABLE>
just emailed you...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEG6ick »</TD></TR><TR><TD CLASS="quote">the main relay controls your fuel pump. you should be able to hear the fuel pump prime and you should hear the main relay click aswell. here the a site that is really informative.
good luck.</TD></TR></TABLE>
awesome site tells you almost everything you need to know about the main relay. even has a trouble shooting diagram. after going through it i think i just may be my main relay. i just need to find another one to swap it out with and see how that goes.
just emailed you...
its really easy to fix. just check the picture and stuff on how the cracks looks like. you save money by just resolidering it, do you have pictures of the main relay?? i'll tell you it its good or not, the crack is very visible.
boosted_soul_94
08-05-2006 09:57 AM
