How To: remove pcv and adding vents
Old Dec 10, 2004 | 04:06 PM
coupon's Avatar
Default How To: remove pcv and adding vents
does anyone know how to remove the pcv on h22's?
im trying to make something similar to a catch can. so if i remove the pcv, do i need to find a fitting that you could thread into that hole, like a 90 degree elbow? i also heard about adding vents? just drill holes and adding fittings but where and what type of fittings?
Old Dec 10, 2004 | 09:10 PM
coupon's Avatar
Default Re: How To: remove pcv and adding vents (slowredhybrid)
i think im going to do this... can anyone tell me if this works...
1. plug the nipple the pcv conects to from the valve cover, screw a fitting in there and a add a hose aimmed down and out of the car
2. add 2 vents on the valve cover, screw in fittings and just leave them like that and let them flow into the atmosphere
Old Dec 10, 2004 | 11:58 PM
coupon's Avatar
i heard if i did this it'll just squirt out strait up oil and not vapors? and does anyone know anything about the "black box" i have to take out or plug up for this to work?
TravisBiggie
Jun 27, 2012 11:52 AM
GoSickemRobert
Apr 11, 2011 08:09 AM
Charlie Moua
Welding / Fabrication
16
Nov 12, 2010 01:38 PM
DFW
Dec 10, 2004 09:52 PM
civicshowracing65
Oct 20, 2004 03:13 PM
