Having problems with my MAP help!!!!
Old Dec 10, 2004 | 01:37 PM
dannydos's Avatar
Default Having problems with my MAP help!!!!
what's up HT.....well i throwing a code 3 which is the map sensor.... so i've checked the voltage at the sensor and i'm getting 5v at the power pin 2.89v at the signal pin and 0v and the ground pin... and when i use my hand vac on the map the signal voltage doesn't change at all.....i've checked the signal voltage at the ecu and it's the same 2.89v....i thought that the signal voltage came from the map not the other way around.....has anybody had this problem or can shine a light onto what's going on here...o yeah i've changed the map sensor sever times and i still get this code...thanks for looking at my thread...
Old Dec 10, 2004 | 04:20 PM
notstock93's Avatar
Default Re: Having problems with my MAP help!!!! (dannydos)
do you have an LS with cams, by any chance?
Check the vacuum as well.
Old Dec 11, 2004 | 04:10 AM
dannydos's Avatar
Default Re: Having problems with my MAP help!!!! (notstock93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notstock93 &raquo;</TD></TR><TR><TD CLASS="quote">do you have an LS with cams, by any chance?
Check the vacuum as well.</TD></TR></TABLE> Yup i have an Ls in a Ek and i do have vacuum....but don't have cams.
Old Dec 12, 2004 | 09:07 PM
notstock93's Avatar
you may have a vacuum leak causing the map to read incorrectly. Happened to me with my 404's in my LS, but you dont have cams, so its just a guess.
Old Dec 12, 2004 | 11:35 PM
skunk2finatic's Avatar
map sensors kinda tricky...if you don't have the right voltage *meaning wire isn't connected completely or ran through switch, etc*, its gonna go off. or clogged vacuum line....Either way, it's gotta be a vacuum problem at the sensor, or eletrical....Just look at the wires to see if any of them are cut and touching metal, that'll do it too.
map sensors too damn sensative to everything... I've had many o problems with map sensors.
Monstarrr*
Sep 3, 2010 08:26 PM
turboed rhd
Mar 17, 2010 08:47 PM
monster_ls/vtec
Aug 21, 2009 05:10 AM
dannydos
Dec 12, 2004 06:17 AM
hatchinprogress
Nov 23, 2004 08:21 PM
