Code 5 MAP sensor help!
Okay, after swapping a b16 motor into my eg hatchback, it threw a code about the map sensor (light blinks 5 times). Changed it and got a map sensor from an ls motor cause i figured that if i had obd0 ls throttle body then i should have ls map sensor. The motor works fine, but it bugs me that the light is still on. Anyone can help me on this situation. Thanks
No the original map sensor was mounted on the VX throttle body. From what ive been told, the ls map sensors were mounted onto the chasis firewall, so i connected a tube from the map sensor to the throttle body. It runs fine, but i want to get rid of the check engine light. Is it cause i have a p28 computer? my old po7 ecu didnt read this until i changed my ecu.
eg93LS
Jun 10, 2009 08:51 PM
