b16a sir2 swap map sensor prob???
Old Dec 10, 2004 | 10:21 AM
amber_eg6's Avatar
Default b16a sir2 swap map sensor prob???
I have a 99cx with a obd1 b16a swap and the only code I cant get to clear is the map sensor. I have replaced the map sensor and it didn't solve the problem if someone could help I would appreciate it.
Old Dec 10, 2004 | 10:23 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: b16a sir2 swap map sensor prob??? (SepsiEK9)
Use a helms manual and check the wires at the sensor, and at the ECU.
Old Dec 10, 2004 | 10:30 AM
klungemonger's Avatar
Default Re: b16a sir2 swap map sensor prob??? (JDM_Ej)
You didn't get the TPS & MAP plugs mixed up did you? they are close together and are the same plug...
Old Dec 17, 2004 | 05:29 AM
amber_eg6's Avatar
Default Re: b16a sir2 swap map sensor prob??? (klungemonger)
no i didn't mix up the two plugs I found the problem the wiring on the map sensor was broke deep inside the harness it had to be done either when i did the swap or someone must have messed with the harness. thanks for the help though
Hatch Man
Dec 2, 2017 11:30 AM
Dc_Ek
Feb 13, 2013 11:47 PM
velisma
Feb 6, 2009 06:08 AM
runeminaEF9
Apr 30, 2006 05:36 PM
