b16a sir2 swap map sensor prob???
I have a 99cx with a obd1 b16a swap and the only code I cant get to clear is the map sensor. I have replaced the map sensor and it didn't solve the problem if someone could help I would appreciate it.
Re: b16a sir2 swap map sensor prob??? (SepsiEK9)
Use a helms manual and check the wires at the sensor, and at the ECU.
Re: b16a sir2 swap map sensor prob??? (JDM_Ej)
You didn't get the TPS & MAP plugs mixed up did you? they are close together and are the same plug...
Re: b16a sir2 swap map sensor prob??? (klungemonger)
no i didn't mix up the two plugs I found the problem the wiring on the map sensor was broke deep inside the harness it had to be done either when i did the swap or someone must have messed with the harness. thanks for the help though
