starting problem?
Old Dec 10, 2004 | 08:22 AM
Rival23's Avatar
Default starting problem?
Ever since i swaped my JDM ITR motor into my GSR whenever I put gas in the car it has trouble starting, and then wont idle right, I have to constantly stay on the gas for 2 or 3 minutes before it will run normal, if I dont do this then it stalls out...does anyone know what could be causing this or how to fix it?
Old Dec 10, 2004 | 08:31 AM
mattssi's Avatar
Default Re: starting problem? (Rival23)
is it only when you go to put gas in it?
Old Dec 10, 2004 | 08:35 AM
hondaracing1on12004's Avatar
check for leaks in the lines or maybe fuel filter is going bad
Old Dec 10, 2004 | 09:23 AM
Rival23's Avatar
Default Re: starting problem? (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">is it only when you go to put gas in it? </TD></TR></TABLE>
yep, only when I put gas in it
Old Dec 10, 2004 | 12:23 PM
turboxsi's Avatar
What year Gsr, because 94-95 gsr (obd1) have a FITV (Fast idle thermal valve) which helps with cold starts. Seeing how your from NOVA and i am too i know its cold. The itr motor is made obd2 and a program in the obd2 ecu controls cold start idles so it doesn't have any use for the FITV, like the 95 and below cars do. So if you did put the itr in a 94-95 gsr then i would suspect that to be the problem, or a sensor malfunction.
I myself don't have the FITV hooked up to my b16 hatch because the itr intake manifold isn't designed for the FITV (which is what i have on my b16). So on cold mornings i have to let my engine warm up alittle more than normal or it will want to stall out. But i just got a 94-95 GSR t/b which has the FITV built onto it instead of built onto the i/m like the older b16s, so my cold starts will improve.
I don't just a thought to consider.
Old Dec 10, 2004 | 01:24 PM
Rival23's Avatar
Default Re: starting problem? (turboxsi)
the car is a 2000 GSR so it was already obd2, the car doesnt just run funny, it actually wont start or stay runnnig unless i pump the gas pedal
Old Dec 10, 2004 | 03:24 PM
turboxsi's Avatar
oh i see, have you checked timing??
Old Dec 10, 2004 | 04:16 PM
Rival23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboxsi &raquo;</TD></TR><TR><TD CLASS="quote">oh i see, have you checked timing??</TD></TR></TABLE>
nope but wouldnt the car run bad all the time if the timing was off?
Old Dec 11, 2004 | 07:55 AM
Rival23's Avatar
bump
come on, someones gotta know whats causing this
Old Dec 11, 2004 | 08:39 AM
junbug66's Avatar
when you try to start your car do you hear your injectors getting fuel? cuz my car used to not get fuel to the injectors. i just swapped the fuel pump and rarely happens anymore
Old Dec 11, 2004 | 09:23 PM
Rival23's Avatar
Default Re: starting problem? (junbug66)
bump
has anyone else had this problem and know how to solve it?
Old Dec 12, 2004 | 04:47 PM
Rival23's Avatar
TTT
Old Dec 17, 2004 | 09:39 AM
Rival23's Avatar
Does anyone know if removing the charcoal canister could possibly cause this?
vi3tromanc3r
Aug 30, 2008 12:10 AM
mr_gs-r
Jun 10, 2006 04:13 PM
PrecisionPerformanceParts
Oct 3, 2005 06:40 PM
igo4bmx
May 20, 2005 12:58 PM
quik1
Dec 19, 2003 03:32 PM
