build-up(help)
Old Dec 9, 2004 | 06:38 PM
civiswapman93's Avatar
Default build-up(help)
Will someone give me a list of all the things I would need to build an engine up from the block. Then tranny info; ecu info; and everything else i would need to know to tear out my old engine and build a new one to put in.
Old Dec 9, 2004 | 06:40 PM
civictildeath's Avatar
Default Re: build-up(help) (civiswapman93)
well we need to know what block you are starting with and what you want to build ie. d16y8 d16z6 etc vtec non vtec
Old Dec 9, 2004 | 06:44 PM
Default Re: build-up(help) (civictildeath)
b16a2
Old Dec 9, 2004 | 06:50 PM
Paprika's Avatar
to build it up from the block you would need an actual engine to replace such a usless piece of metal. It will costs you oodles of $$$$ if all you have is a bare block w/o pistons and stuff.
Old Dec 9, 2004 | 06:53 PM
Br1anPham's Avatar
Default Re: build-up(help) (Paprika)
Get a big piece of rock. Buy a air chisel. Start grinding and chiseling away. Soon enough, your motor will take shape!!! Thats how I build mines.
Use the search button to search for what you need to know.
Old Dec 9, 2004 | 06:54 PM
block- crankshaft, main bearings, connecting rods, pistons, piston rings, oil pump, sensors, crank gear
head- valves, valve springs, vavle spring retainers, camshaft, cam gear, thermostat housing, vavle cover, distibutor,
brain fart i cant think right now but here is a start
Old Dec 9, 2004 | 06:56 PM
i have an engine in my car i want to build another one to put in. I want to build it from the block
Old Dec 9, 2004 | 06:59 PM
anything more? What would be a good website to go to?
Old Dec 9, 2004 | 07:01 PM
http://www.hondaautomotivepart...cgry5=
just browse through here and you will get pics of the parts. remember that these parts are OEM. but they can help get you going
Old Dec 9, 2004 | 07:13 PM
thanx
Blacknight117
25
Mar 6, 2011 05:42 PM
B00stedEh3
Aug 5, 2007 08:04 PM
bitz95civ
Jul 12, 2007 02:09 PM
dixie Normas7
Aug 23, 2006 11:43 AM
tommy69z
Feb 6, 2005 06:37 PM
