build-up(help)
build-up(help)
Will someone give me a list of all the things I would need to build an engine up from the block. Then tranny info; ecu info; and everything else i would need to know to tear out my old engine and build a new one to put in.
Re: build-up(help) (civiswapman93)
well we need to know what block you are starting with and what you want to build ie. d16y8 d16z6 etc vtec non vtec
to build it up from the block you would need an actual engine to replace such a usless piece of metal. It will costs you oodles of $$$$ if all you have is a bare block w/o pistons and stuff.
Re: build-up(help) (Paprika)
Get a big piece of rock. Buy a air chisel. Start grinding and chiseling away. Soon enough, your motor will take shape!!! Thats how I build mines.
Use the search button to search for what you need to know.
block- crankshaft, main bearings, connecting rods, pistons, piston rings, oil pump, sensors, crank gear
head- valves, valve springs, vavle spring retainers, camshaft, cam gear, thermostat housing, vavle cover, distibutor,
brain fart i cant think right now but here is a start
http://www.hondaautomotivepart...cgry5=
just browse through here and you will get pics of the parts. remember that these parts are OEM. but they can help get you going
dixie Normas7
08-23-2006 11:43 AM
