cutting oil?
It depends on what type of system you are using really... If you have to put the oil on it yourself i suggest rapid tap which works excellent for pretty much everything that doesnt require a flooding type coolant system.
If you band saw has a water pump i suggest some Valcool... i personally use VNT 935 coolant... but its also $130.00 for a 5 gallon pale of it while most collants are about $25 for 5 gallons, for a lower budget coolant concentrate try VNT-800 from val-cool. the problem with a lot of coolants out there is most will not work in tap water. it needs to be purified but VNT-800 works in it and is about $12.00/gallon, and 1 gallon of it makes about 15 gallons of coolant.
we used to use the mobil stuff at my old work i dont rember the name of it, worked good though, we use this clear green stuff now at my work, its super think and has high lubricity but i dont know how good it is on metal, we cut glass with it on a diamond blade, and the stuff is like 3000 for a 55 gallon drum
i would not use wd40 on my bandsaw. i use either a high speed cutting oil, or air tool lubricant. i like the air tool stuff because it is clear and you can still see your markings. good luck!
kyle
kyle
XLR8 GS-R
Welding / Fabrication
Dec 19, 2007 07:45 AM
SPORT INJECTION
Aug 25, 2003 12:15 PM
