CEL light for Vtec pressure switch comes on under boost
well, driving my car regularly I have no codes and the car runs perfect. But under hard acceleration and when boost kicks in, the check engine light comes on, and it's always code 22 (vtec pressure switch). I have a d16z6 w/ uberdata.....anyone else ever have this issue??
-jase
-jase
Same thing happened to me a while back, with my stock gsr motor. I was low on oil. . You sure it's not code 23? I could have sworn it was 23. Ohh well, that was over a year ago.
And BTW, I cracked a sleeve and all the ringlands the next day. I don't think it was related, but w/e.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shiftgear8000 »</TD></TR><TR><TD CLASS="quote">well, driving my car regularly I have no codes and the car runs perfect. But under hard acceleration and when boost kicks in, the check engine light comes on, and it's always code 22 (vtec pressure switch). I have a d16z6 w/ uberdata.....anyone else ever have this issue??
-jase</TD></TR></TABLE>
I am having the exact same problem.
I am running a restrictor in my oil aswell, which was made even smaller to hopefully fix the problem, and it still happens?
Bump for some more input on this issue.
I'd say low oil or messed up pickup. I get that code every now and then if I'm down 1/2 a quart and take this one particularly fun exit ramp at around 85. God Azenis are fun
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">I'd say low oil or messed up pickup. I get that code every now and then if I'm down 1/2 a quart and take this one particularly fun exit ramp at around 85. God Azenis are fun
Low oil wasn't the case as there was plenty. So you think it may be oil pump pick up?
</TD></TR></TABLE>Low oil wasn't the case as there was plenty. So you think it may be oil pump pick up?
more info please.....this problem is really pissin me off lol. Is it possible the vtec solenoid is bad??? The code goes away as soon as I shut the car off and turn it back on. But it's really pissin me off lol.
-jase
-jase
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shiftgear8000 »</TD></TR><TR><TD CLASS="quote">would having too much oil in the car also cause this problem???
How about your tune your car?
Modified by Sick00SiCoupe at 1:48 AM 9/6/2005
