Different axle nut sizes?
Old Dec 8, 2004 | 06:07 PM
d15b7racer's Avatar
Default Different axle nut sizes?
i recently got an axle from when i bought my motor and the nut size is different. the axle goes into the trans and hub fine its just that when i try to put my old nut (32 mm) its too big. I didnt know that different axles have different sizes. where would i get this size nut or do i just have the wrong axle (yet still fits into my car perfectly)?
Old Dec 8, 2004 | 06:08 PM
Ricey McRicerton's Avatar
Default Re: Different axle nut sizes? (d15b7racer)
Sounds like you may have the wrong axle or you aern't seating the axle nut correctly or something. The only "Civic" axles that are a different size are the JDM ITR 36mm units. Everything else is 32mm.
Old Dec 8, 2004 | 06:12 PM
d15b7racer's Avatar
Default Re: Different axle nut sizes? (Ricey McRicerton)
but the axle threaded part is too small....not too large. so wouldnt my nut need to be smaller?
Old Dec 8, 2004 | 06:14 PM
iBear's Avatar
hmm..seems to me that you have the wrong axle, but all b series axles are interchangeable..hmmm
edit: looking at your username, you do not have a b series. my bad.
Old Dec 8, 2004 | 06:16 PM
d15b7racer's Avatar
Default Re: Different axle nut sizes? (EJellyfish1)
oh yeah....sorry swapped in a d16z6. and axles are different.....arent ALL D series axles interchangeable? oh yeah....i'm for sure its a non abs model too.
Old Dec 8, 2004 | 06:18 PM
iBear's Avatar
so everything fits in perfectly, except for the nut?
When the axle is in the hub, do the little teeth thing line up right? or is the axle kind of loose in there?
Old Dec 8, 2004 | 06:19 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15b7racer &raquo;</TD></TR><TR><TD CLASS="quote">but the axle threaded part is too small....not too large. so wouldnt my nut need to be smaller?</TD></TR></TABLE> I never met anyone who wanted their nuts to be smaller... Just playin bro. No the D15B still has the same 32mm axel nuts. There isn't any play at all between the splines on the axel and the ones on the hub? This is very strange...
Old Dec 8, 2004 | 06:23 PM
d15b7racer's Avatar
Default Re: Different axle nut sizes? (HondaFanatic708)
i'll take pics right now.....brb
Old Dec 8, 2004 | 06:29 PM
d15b7racer's Avatar
okay upon further inspection.....the axle on the side that doesnt fit is a little bit shorter. its weird though because it fits the hub totally perfect. just a little short coming out of the hub. now a new question.....can someone tell me what axle this is?
angrysmileyface
Oct 11, 2015 03:57 PM
blk01geezer
Oct 7, 2010 01:27 AM
ev13lf
Oct 30, 2008 06:59 AM
MugenHonda
Dec 30, 2005 10:38 AM
whitehf
Dec 7, 2004 02:08 PM
