Need help trying to get a siezed O2 sensor out of a DC header
Old Dec 8, 2004 | 04:51 PM
crazy eyez killa
Guest
Posts: n/a
Default Need help trying to get a siezed O2 sensor out of a DC header
I have a DC ceramic header and the sensor is stuck in it.
I've tried a 22 mm wrench (closed end) with a breaker bar and it started to strip the O2.
Any suggestions?
Modified by DEEZ NUUTS at 10:33 PM 12/8/2004
Old Dec 8, 2004 | 08:58 PM
Cjsls's Avatar
Default Re: Need help trying to get a siezed O2 sensor out of a DC header (DEEZ NUUTS)
i believe they sell a special socket that will slip over the o2 sensor, you could use that if it isn't rounded off already. or a pair of vice grips. i unno thats all i can think of for now.
Old Dec 8, 2004 | 09:08 PM
eda6's Avatar
Default Re: Need help trying to get a siezed O2 sensor out of a DC header (Cjsls)
I'd spray some nut loosener on it, then try to remove it. Maybe it needs to be tightened a little more then unloosened.
Try a 6 point 22mm closed wrench and a bfh.
Old Dec 8, 2004 | 09:20 PM
PrettyLude's Avatar
pb blaster, try a 7/8 wrench
Old Dec 8, 2004 | 11:07 PM
95hatch's Avatar
Default Re: (PrettyLude)
maybe apply a bit of heat to it with a torch.
Old Dec 9, 2004 | 06:57 AM
SOHFAST94's Avatar
Old Dec 9, 2004 | 03:14 PM
powerfulperformance's Avatar
Default Re: (SOHFAST94)
yep, heat it up....that will work..
atmosphere
Jan 20, 2006 02:52 PM
TommyBB
Dec 22, 2005 11:22 PM
simplypinoyy
14
Jul 26, 2004 07:50 PM
RaceStyles
Nov 20, 2003 08:01 PM
StyleTEG
Jul 5, 2002 10:28 PM
