idle problem
Old Dec 8, 2004 | 01:50 PM
b16delsol's Avatar
Default idle problem
hey i have a 93 del sol with a jdm b16a2 in it and i have to run my d16z6 throttle body on it because the one that came with the engine didnt have a map sensor on it, my idle pulses from 1500 to 2000 at idle. i was thinking it could be the tps sensor can anyone help me?
thanx
joe
Old Dec 8, 2004 | 01:54 PM
JDMallTHEway's Avatar
Default Re: idle problem (b16delsol)
no such thing as a jdm b16a2
you prolly have a 2nd gen B16a
umm, why didnt you use the throttle body for the b1 and get a new map sensor for it?
Old Dec 8, 2004 | 03:42 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: idle problem (JDMallTHEway)
There should be a little brass tube sticking out of the front (as in the side that will be towards the front of the car) of the JDM throttle body. This is your MAP connection. Get a small vac line and run it that way...
Old Dec 8, 2004 | 05:36 PM
Default Re: idle problem (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">There should be a little brass tube sticking out of the front (as in the side that will be towards the front of the car) of the JDM throttle body. This is your MAP connection. Get a small vac line and run it that way...</TD></TR></TABLE>
What he said. I have the map sensor for it somewhere, I'd sell it for $15 to you.,
It was on my motor, but I had to get the stick on kind for my edelbrock throttlebody.
aasaa666
Jun 29, 2008 08:13 PM
crfr230
Apr 24, 2007 07:48 PM
mikeunreal
Oct 26, 2005 05:31 PM
asubennett
Sep 30, 2003 03:19 PM
