LS distributor with VTEC head?
Old Jan 2, 2002 | 12:09 PM
HX_Guy's Avatar
Default LS distributor with VTEC head?
Ive heard that if you chop off one of the legs on the LS distributor, it can be used with a VTEC head.
Does anyone have experiance with this? Does it work exactly the same as a VTEC one would or are there other differances?
Old Jan 2, 2002 | 12:46 PM
sgT's Avatar
sgT
Default Re: LS distributor with VTEC head? (HX_Guy)
it works.
cheap alternative to a vtec distributor
Old Jan 2, 2002 | 04:28 PM
Haltom Hatch's Avatar
Default Re: LS distributor with VTEC head? (sgT)
yeah it does work just chop off the leg that hits the vtec sol. a dist. is a dist. the only difference is the wiring harness connections
Old Jan 3, 2002 | 06:25 AM
pregunta's Avatar
Default Re: LS distributor with VTEC head? (RipNTeg)
the wiring harness is only different if one thing is from an obdI and the other is from an obdII. I have one aready set up for that from a obdII car. Cheap cheep let me know. ( you won't have to hack up the one you have and can save it or sell it)
Old Jan 3, 2002 | 06:28 AM
HX_Guy's Avatar
Default Re: LS distributor with VTEC head? (pregunta)
Thanks but mine is already hacked, it used to be a OBDI distributor and I rewired it for OBDII
Old Jan 3, 2002 | 06:46 AM
rainforest's Avatar
yeah i have a non vtec dist on my car only using one boltand never had the slightest probem.
Old Jan 3, 2002 | 12:18 PM
One8Hatch's Avatar
New User
Default Re: LS distributor with VTEC head? (rainforest)
with only one bolt holding it on there, are you still able to advance or retard your distributer? thanks
Old Jan 3, 2002 | 12:28 PM
HX_Guy's Avatar
Default Re: LS distributor with VTEC head? (One8Hatch)
Do you still have full adjustabilty as well with the LS dist. on a VTEC engine? Like can I retard or advance the timing +/- 10 degrees?
Old Jan 3, 2002 | 01:13 PM
sgT's Avatar
sgT
yes, but for you it wont matter because you are getting a hondata.
Old Jan 3, 2002 | 01:17 PM
HX_Guy's Avatar
Oh yea huh
But when I adjust the cam gears...Ill still want to adjust the distributor as well right?
Old Jan 3, 2002 | 01:31 PM
sgT's Avatar
sgT
yes. but you wont be adjusting the intake cam THAT much
Old Jan 3, 2002 | 01:32 PM
brinks's Avatar
Two bolts, one on top and one on the back end of the distributor.
TravisBiggie
May 29, 2012 04:06 PM
Rigginit
Dec 26, 2009 09:57 PM
D-rush08
Sep 7, 2006 10:08 AM
Racer338
Dec 11, 2003 11:16 AM
Audi A4
Sep 15, 2003 09:26 AM
