Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Turbosmart Wastegate starts @ $ 275 plus free braided wastegate line kit !!
Old Dec 8, 2004 | 09:46 AM
Flamenco-T's Avatar
Default Turbosmart Wastegate starts @ $ 275 plus free braided wastegate line kit !!
We're back again !!!!
We are happy to announced that we will be carrying all the complete Turbosmart products.
TURBOSMART is Australia’s leading manufacturer of turbo accessories. Our aim is to provide the world market with innovative, cost effective products that will greatly enhance the performance of any turbo charged vehicle. TURBOSMART products are not only affordable and easy to install, but are finished to appeal to all motoring enthusiasts. All products are tested to meet the highest industry standards. Innovation, quality, and affordability are the company focus.
Now to the good stuff
Turbosmart Ultra-Gate 38 Wastegate
The most compact 38mm wastegate on the market, featuring the common two bolt flange design used by many turbo kit manufacturers. The Ultra-Gate’s design incorporates a unique temperature isolation zone to reduce heat transfer, a true 35mm inlet port for maximum flow, an investment cast Stainless Steel body and one-piece valve for strength and reliability. We have successfully used one Ultra-Gate on engines producing up to 600HP.
*Ultra compact 112mm overall height (4.5 inch) and 100mm across (4 inch)
*17-7 PH spring and Silicone Nomex diaphragm - durability under extreme temperatures and stress
*Optimum actuator to valve ratio for precise boost control
*Superior body design and huge valve lift ensure unrivalled flow
*Supplied with weld on steel manifold flanges and gaskets
*Fully compatible with all Turbosmart Boost Controllers
Best features
1. The Ultra Gate will bolt up to the turbonetics deltagate or the tial 35/38mm flange.
2. All Ultra-Gate 38 will come with 4 different spring combination; 7 psi, 10 psi, 14 psi and 17 psi. No need to buy an additional spring ever again !!
3. All Ultra-Gate 38 will come with a leaded gas compatible valve, no need to buy a leaded valve unlike the competitors
Comparison picture with Tial 38mm, the Ultra Gate is about 3/4" shorter
For limited time, with all wastegate purchase until the end of the year, you will also get a FREE Stainless Braided Wastegate Line Kit
This will allows you to run a stainless braided line kit directly from your wastegate to the compressor housing of your turbo, no more silicone hose popping off !!!! Stop overboosting !!!
$ 275 plus Free Wastegate Line Kit !!
Color: Available in Blue, Black, Red and Silver(polished).
Turbosmart Pro-Gate 48 Wastegate
Time proven reliability and extreme performance has made the Turbosmart Pro-Gate the external wastegate of choice by many of the world’s fastest drag racers and builders of hardcore horsepower machines. The Pro-Gates design includes an investment cast Stainless Steel body, a one-piece valve for strength and reliability and the unique temperature isolation zone to reduce heat transfer. The Pro-Gate is supplied complete with a cast Stainless Steel Vee-band adapter kit for quick and easy installation. We have successfully used one Pro-Gate on engines producing up to 1000HP
*Race proven winner! Drag racers choice!
*Extensively developed body design and huge valve lift ensure unrivalled flow
*Supplied with Vee-bands and weld flanges
Best features
1. The Pro-Gate comes with the same size V-band outlet and inlet.
2. All Pro-Gate 48 will come with 5 different spring combination; 7 psi, 10 psi, 14 psi, 17 psi and 21 psi. No need to buy an additional spring ever again !!
3. All Pro-Gate 48 pricing is much lower than competitor's pricing for greater capabilities and quality
Comparison picture with Tial 44mm
V-band inlet and outlet. Tial on the left hand side
Valve comparison, Tial on the left hand side
$ 475 plus Free Wastegate Line Kit !!
You can also substitute the Wastegate Line kit for the CMZ kit
Added Bonus: For those of you who run a 40mm Tial 4 bolt style flange, we also offered the conversion kit from your WG flange to run the Pro-Gate 48mm
$ 75
Ordering Info
Give us a call, 888-887-2658 and we'll take care the rest !!
We accept Visa, MC, Amex, Paypal, check or MO
thanks again for the support guys..
Stan
Modified by Flamenco-T at 1:59 PM 1/25/2005
Old Dec 8, 2004 | 07:15 PM
D@nnY's Avatar
ordering an ultragate...UP
Old Dec 8, 2004 | 08:40 PM
LBR92DA-T's Avatar
if i was still building my turbo car... i would be all over the 48mm so sexy...
Old Dec 8, 2004 | 09:03 PM
11psiTurboSI's Avatar
Default Re: (LBR92DA-T)
good stuff
Old Dec 9, 2004 | 07:14 AM
braintree's Avatar
Default Re: Turbosmart Wastegate starts @ $ 275 plus free braided wastegate line kit !! (Flamenco-T)
Good deal
Old Dec 11, 2004 | 05:26 AM
ekek888's Avatar
price shipped? what spring comes w/it?
Old Dec 11, 2004 | 02:33 PM
D@nnY's Avatar
Default Re: Turbosmart Wastegate starts @ $ 275 plus free braided wastegate line kit !! (ekek888)
Read the post again it comes with 4 springs...Up!
Old Dec 16, 2004 | 10:12 AM
Flamenco-T's Avatar
Default Re: Turbosmart Wastegate starts @ $ 275 plus free braided wastegate line kit !! (D@nnY)
thanks d@nny
ekek8888: it comes with 7,10,14,17 psi on the 38mm. On the 48mm it comes with a 21 psi as well on top of the above
stan
Old Dec 21, 2004 | 04:13 PM
D@nnY's Avatar
Ordered a quaife and an ultragate...good guy good service...
Old Dec 27, 2004 | 07:43 PM
93hatched_projekt's Avatar
Default Re: (D@nnY)
pm sent
Old Jan 25, 2005 | 10:57 AM
Flamenco-T's Avatar
Default Re: (93hatched_projekt)
uppity
Old Jan 28, 2005 | 10:47 AM
integlspwr2k's Avatar
Default Re: (Flamenco-T)
wow that 40mm to 48mm adapter flange is very very pretty.
Old Jan 28, 2005 | 08:05 PM
downeyballz's Avatar
is the wastgate line kit still included, and is that price including shipping?
Old Jan 30, 2005 | 07:57 PM
Flamenco-T's Avatar
Default Re: (downeyballz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz &raquo;</TD></TR><TR><TD CLASS="quote">is the wastgate line kit still included, and is that price including shipping?</TD></TR></TABLE>
Yes, the wastegate line kit is included. Shipping is also included within all 50 US states.
thanks
Stan
NumberB
Apr 23, 2006 02:45 PM
Flamenco-T
Apr 17, 2005 09:56 PM
B18C4-T
Feb 9, 2005 06:57 AM
abmerop18
Jan 27, 2005 08:05 AM
jwcardy
Sep 5, 2004 02:06 PM
