Anti-Freeze goes here or there?
Old Dec 8, 2004 | 07:54 AM
just4747's Avatar
Default Anti-Freeze goes here or there?
Are you supposed to pour antifreeze directly into the cooling fan through the radiator cap hole or do u fill up the white reservoir to the left of the fan that has the hose going to the fan??
Old Dec 8, 2004 | 08:03 AM
white ex's Avatar
Default Re: Anti-Freeze goes here or there? (just4747)
the coolant doesn't go into the fan it goes in the radiator and through the motor. the fan just pulls air through the radiator to help cool it. what are you trying to do refill the system after a flush or are you just adding coolant ?
Old Dec 8, 2004 | 08:15 AM
just4747's Avatar
Default Re: Anti-Freeze goes here or there? (white ex)
just adding cause once in a while, i cant see any coolant under the radiator cap or in the reservoir...so where should i pour it in when adding new coolant??
Old Dec 8, 2004 | 08:16 AM
just4747's Avatar
is the separate white reservoir just for overflow?
Old Dec 8, 2004 | 08:19 AM
DC-4-Drew's Avatar
If you engine is hot you can add fluid in the overflow bladder, if you engine is cool you can add into the radiator. Be sure not to confuse the overflow with the Wiper fluid canister.
Old Dec 8, 2004 | 08:34 AM
white ex's Avatar
you should top off the radiator ( when cold ) and fill the reservoir up to a little more than half way between the min and max lines. do you have any leaks cause the reservoir shouldn't empty completely.
Old Dec 8, 2004 | 12:41 PM
just4747's Avatar
nope..it wasnt completely empty though so thats good...just a little low...but when u open the radiator cap, its okay to not see any coolant right?
Old Dec 8, 2004 | 12:45 PM
jefe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white ex &raquo;</TD></TR><TR><TD CLASS="quote">you should top off the radiator ( when cold ) and fill the reservoir up to a little more than half way between the min and max lines. do you have any leaks cause the reservoir shouldn't empty completely.</TD></TR></TABLE>
This happens to me over a long period of time. What is the best [ easiest ] way to check for leaks?
fuglybutruns
Jul 28, 2015 07:50 PM
TailZ
Honda Civic (2001 - 2005)
Jun 14, 2010 10:52 AM
spock_rocker
Jun 6, 2005 03:32 PM
92VtecTeggy
Jun 20, 2003 08:13 AM
PearlWhiteAccord
Sep 25, 2002 12:15 PM
