Has anyone ever herd of this!!!!
Old Dec 7, 2004 | 08:01 PM
ATS*Mark's Avatar
OG triple OG
Default Has anyone ever herd of this!!!!
today i was driving and all of a sudden my lights turned off , my radio turned off , and my motor shut off with a CEL.....troubleshooting narrowed it down to my under hood fuse box!!!!!!!!! i could wiggle the ground wire that goes into the fuse box and the car lights would go on and off. has anyone ever experienced this?
Old Dec 7, 2004 | 08:02 PM
JDM96SpecCTR's Avatar
Default Re: Has anyone ever herd of this!!!! (Hella_JDM)
did u open the box? there should be 2 screws holding the wires to it, check if they r tight
Luserkid's Avatar
Loose ground then? Tighten it down and you should be good to go.
Old Dec 7, 2004 | 08:09 PM
Built Beast's Avatar
Default Re: Has anyone ever herd of this!!!! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Loose ground then? Tighten it down and you should be good to go. </TD></TR></TABLE>
Yeah, maybe it has something to do with a loose wire in the dizzy too becase this kind of thing happened to my friend the other day, but no CEL just turned off. I don't know, but it is worth a shot.
Old Dec 7, 2004 | 08:16 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Has anyone ever herd of this!!!! (R33CIVIC)
naw i tried tightening the ground wire down , it was tight
its the contact inside the fuse box . the wire looks really good . if i take the wire off and pry the little metal thing up on the box it works...so i know its the box . how wierd is that!
Old Dec 7, 2004 | 08:18 PM
kind of crazy that it just decided to come loose.
EDIT: atleast you found the problem...
Old Dec 7, 2004 | 08:20 PM
ATS*Mark's Avatar
OG triple OG
ya man everything just started ******* up randomly in my car. my speedo started acting wierd then shut off.....my hazards stoped working along with my turn signals....then it it started shuting off . wierd huh?
Old Dec 7, 2004 | 08:44 PM
-Gambit-'s Avatar
never heard of that problem, but atleast you figured it out. Maybe you need some rotas on your hatch, i heard that by putting rotas on a car you wont have any problems
Old Dec 7, 2004 | 08:48 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Has anyone ever herd of this!!!! (-Gambit-)
id rather have my car not run!!!!
Old Dec 7, 2004 | 09:36 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">today i was driving and all of a sudden my lights turned off , my radio turned off , and my motor shut off with a CEL.....troubleshooting narrowed it down to my under hood fuse box!!!!!!!!! i could wiggle the ground wire that goes into the fuse box and the car lights would go on and off. has anyone ever experienced this?</TD></TR></TABLE>
umm there arent any ground wires in you fuse box... they're all (+). it's no suprise that you electrical stuff went nuts. your symptoms actually sound like you had a bad altenator. good thing it was an easy fix tho
Old Dec 7, 2004 | 09:39 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Has anyone ever herd of this!!!! (dantastic)
thats not a ground? when would i be able to move that wire over to my other positive side?
Old Dec 7, 2004 | 09:40 PM
ATS*Mark's Avatar
OG triple OG
it did seem like a bad alt!!! my voltage while driving would go up to 12.8 , then down to 11.9 it never got to 14 at all.....so wierd.
Old Dec 8, 2004 | 05:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">it did seem like a bad alt!!! my voltage while driving would go up to 12.8 , then down to 11.9 it never got to 14 at all.....so wierd.</TD></TR></TABLE>
yup sounds like the alt to me too
Old Dec 8, 2004 | 06:42 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Has anyone ever herd of this!!!! (JDM96SpecCTR)
its not , the ELD is in that fuse box.....
Old Dec 8, 2004 | 06:43 AM
smithenhiven's Avatar
11:11
I had that happen in a 1974 Firebird I used to own. It's pretty scary as your riding down the road, and all of a sudden your car shuts off.
Old Dec 8, 2004 | 01:51 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Has anyone ever herd of this!!!! (evan2)
underhood fuse box fixed it today
codybuRr
14
Feb 7, 2011 05:26 PM
hybrid1990crx
Oct 15, 2010 04:35 PM
JapJunkie
Welding / Fabrication
11
Jun 9, 2006 02:06 PM
Boarderx192
Dec 5, 2005 07:35 AM
