Mount problem for H22 swap in a 5th Gen.
Old Dec 7, 2004 | 07:51 PM
Luserkid's Avatar
Default Mount problem for H22 swap in a 5th Gen.
Ok im doing a swap for a friend and i ran into a pretty big problem, and that being the driver side mount. Which one do i use, or could i cut this piece off and make it fit: (off a F22)
Left is F22 mount and H22 mount:
And this is the only mount i have to go with them, it only fits the F22 mount. Do i need to get a prelude version of this mount?
TIA!
Old Dec 7, 2004 | 09:18 PM
HAccord96's Avatar
Default Re: Mount problem for H22 swap in a 5th Gen. (Luserkid)
You will need an entire H22 top and lower part for the driver's side mount.
Old Dec 8, 2004 | 04:13 AM
iakona's Avatar
and sell both of those driver's side mount pieces when you're done!! seriously.
Old Dec 8, 2004 | 08:16 PM
accord-lude's Avatar
You could basically use the prelude mount and prelude bracket, but you have to grind down the mount to fit. What I do on my accord is ... I used my accord mount on the prelude bracket, and drill another hole for the other bolt with a electrical driller.
Old Dec 9, 2004 | 02:57 PM
95allmotor's Avatar
Default Re: Mount problem for H22 swap in a 5th Gen. (accord-lude)
Nice choice for a swap, the H22a is a great motor for playing with imo. Hoping to boost one some day.
Old Dec 9, 2004 | 03:11 PM
smooth95's Avatar
use the prelude mount and just open the accord frame up a little
Old Dec 9, 2004 | 09:10 PM
AVcTcEoCrd's Avatar
Default Re: (smooth95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smooth95 &raquo;</TD></TR><TR><TD CLASS="quote">use the prelude mount and just open the accord frame up a little</TD></TR></TABLE>
opening the frame is not as easy as you think. just use the lude mount and grind it down a little bit. that is what i did and it fits perfectly.
Old Dec 9, 2004 | 09:52 PM
HAccord96's Avatar
Default Re: (AVcTcEoCrd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVcTcEoCrd &raquo;</TD></TR><TR><TD CLASS="quote">
opening the frame is not as easy as you think. just use the lude mount and grind it down a little bit. that is what i did and it fits perfectly.</TD></TR></TABLE>
You are right. If you widen the space, the threads on the welded-on nut towards the firewall where the long bolt screws into might not be in line anymore. The best way is to grind down the prelude mount. It should take 5 minutes.
Old Dec 9, 2004 | 10:07 PM
AVcTcEoCrd's Avatar
Default Re: (HAccord96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAccord96 &raquo;</TD></TR><TR><TD CLASS="quote">
You are right. If you widen the space, the threads on the welded-on nut towards the firewall where the long bolt screws into might not be in line anymore. The best way is to grind down the prelude mount. It should take 5 minutes.</TD></TR></TABLE>
T9U4ReBgO
Sep 8, 2010 06:49 PM
91hybridAccord
Jan 20, 2006 02:01 PM
OutlawCL
Oct 2, 2004 11:32 PM
H22CL
Sep 29, 2004 09:51 AM
OutlawCL
Sep 11, 2004 01:20 PM
