Cant get axle lugs off
Old Dec 7, 2004 | 06:58 PM
EriK20's Avatar
Default Cant get axle lugs off
I am doing a break up grade to my 93 civic hatch and i cant get the axle lugs off. i have already broken one breaker bar and had to replace it and i have put like a half a can of wd40 and liquid wrench on them. dose anyone have an idea?
Old Dec 7, 2004 | 07:09 PM
DohcSide's Avatar
Default Re: Cant get axle lugs off (EriK20)
go to the suspention forum they probably can help you over there
Old Dec 7, 2004 | 07:12 PM
Syner-G-Racing LLC's Avatar
did you straighten the crimp out from the notch? if so turn the wheel all the way to one side and smack it with a hammer a few times, if its siezed that should help crack it...pb blaster is much better than wd40, even liquid wrench, they penetrate better than just lubricant.
Old Dec 7, 2004 | 07:14 PM
EriK20's Avatar
Default Re: Cant get axle lugs off (Syner-G-Racing)
thanx
Old Dec 7, 2004 | 07:17 PM
jefe's Avatar
Use PB Blaster. A good [ patient ] technique is to spray an *** load of PB on it. Let it sit, tap it a few times. Soak it again and let it sit overnight. Maybe even 2-3 days. I have done this before and the stuff just falls off. [ figure of speach ]. Have to be patient for this to work though.
good luck.
Old Dec 7, 2004 | 07:20 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Brake upgrade which I am assuming includes the rotors as well?
I'm going to message you.
JDM96SpecCTR's Avatar
on my 91 si i broke 2 breaker bars, used a can of wd basically, hammer and chisel, a blow torch, drilled it, used an electric impact, and finally an air impact. i just sat there and let it pound away, going fwd and rev on it, and it eventually let loose. not fun, but when it finally came off i felt like the champ. i think i might still have that nut around, if i do i should post pics for u guys to see what it looked liike when i was done
Old Dec 7, 2004 | 07:28 PM
lohatch's Avatar
an impact wrench would work quite nicely, but i dont think you have access to one, in which case a breaker bar and a long *** pipe could be your friend.
Old Dec 7, 2004 | 07:42 PM
jbscivichb92's Avatar
Default Re: Cant get axle lugs off (lohatch)
breaker bar+10 foot fence post=axle nut removed
Old Dec 7, 2004 | 08:17 PM
Default Re: Cant get axle lugs off (jbscivichb92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbscivichb92 &raquo;</TD></TR><TR><TD CLASS="quote">breaker bar+10 foot fence post=axle nut removed</TD></TR></TABLE>
thats exactly what i did, and the square head on the bar that goes into the socket shattered.....2 times
depends on the nut...the one on my 96 came off easily with like a 4 ft pole, but the 91 wasnt going anywhere, and the car already had a swap in it
Old Dec 7, 2004 | 10:21 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Cant get axle lugs off (JDM96SpecCTR)
Yeah air power is cetainly the way to go. As mentioned make sure the nut isn't still punched into that notch. **** man doin a tranny on my old EG we broke 14 tools, only 1 wasn't on the axel nuts. After a while we shot out the gears on 2 old rachets because we knew we could, new tools are nice. It sucked cause the only one who owned a car there was me and it was on blocks. So bummin rides to replace needed tools really sucked. But if you don't have a compressor I would suggest a craftsman or snap-on I-beam handle (sometimes referred to as flex) with an impact tip. Those ******* still break, but not as easily. Don't you just feel like such a manly man when you break solid steel! **** YEAh!!! LOL.
teamvirus
Dec 17, 2005 02:56 PM
91-lsvtecsi
Suspension & Brakes
Oct 18, 2005 07:57 AM
FlsFinest
10
Oct 12, 2005 02:39 PM
B17CRXracer
34
Jun 19, 2005 11:13 PM
brent_G
Apr 26, 2002 11:18 AM
