LOOKING FOR AN OVERDRIVE PULLEY
Old Dec 7, 2004 | 01:29 PM
tcr03's Avatar
Default LOOKING FOR AN OVERDRIVE PULLEY
i am in search of a smaller pully for my alternator. yep thats right a smaller(overdrive) pulley. any help would be great.
Old Dec 7, 2004 | 01:31 PM
Kamin's Avatar
Default Re: LOOKING FOR AN OVERDRIVE PULLEY (tcr03)
you can burn the alternator up doing that, be carefull.
Old Dec 7, 2004 | 03:25 PM
tcr03's Avatar
Default Re: LOOKING FOR AN OVERDRIVE PULLEY (Kamin)
i dont want to go much smaller. the problem is that i got a high output alternator and at idle the car is pretty much running off of the battery. the volts drop down to like 12v and sumetimes lower. and thats with no drain on it at all. the alt doesnt start working till about 1300rpms. so if i get an overdrive pulley that should help out.
Old Dec 7, 2004 | 03:28 PM
jlacoy82's Avatar
71.192.16.183
Have you considered the voltage regulator? RPM's affect amperage, not so much voltage.
Old Dec 7, 2004 | 03:40 PM
tcr03's Avatar
Default Re: LOOKING FOR AN OVERDRIVE PULLEY (jlacoy82)
no i havent. i just got the alternator and i cant imagin the regulator would allow it to drop that low being so new.
Old Dec 7, 2004 | 03:48 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Have you considered the voltage regulator? RPM's affect amperage, not so much voltage.</TD></TR></TABLE>
^He's got a point there.
Old Dec 7, 2004 | 03:51 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tcr03 &raquo;</TD></TR><TR><TD CLASS="quote">no i havent. i just got the alternator and i cant imagin the regulator would allow it to drop that low being so new.</TD></TR></TABLE>
lol still probably uses used parts, most manufacturers do.
Old Dec 7, 2004 | 03:55 PM
XoUnKoWnXo's Avatar
I think Unorthodox racing makes pulley's for alternators. I am not sure though.
thehatchninja
Aug 29, 2006 07:01 PM
BigC-ivic
Oct 23, 2004 10:30 PM
StyleTEG
Audio / Security / Video
Mar 25, 2004 02:37 PM
el402
May 17, 2002 06:55 AM
Tyson
May 13, 2002 12:08 PM
