is this motor salvagable????
well i bought this motor from a friend of a friend for $50
he said it was in good shape that it didnt have a 3rd maincap due to it was frozen to a bearing which was frozen to the crank.
well i was wondering if it can be fixed or better yet worth the time and money to fix it. im planning on getting it sleeved and all so im not worried about the little rust in the cylinder walls.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo »</TD></TR><TR><TD CLASS="quote">rust sucks</TD></TR></TABLE>
take the block to a machine shop and see what they can do for you. looks like you should be able to fix her up. but if not. make a table out of it!
if the sleeves are bad then u can just resleeve it. i would check the crank journals to make sure they are all within spec. the main studs can be change and the oil squirters can be changed.
Chances are if you are going to put a new cap on it, you will HAVE to have it align honed which isn't really a big deal.
Golden Eagle can do both the align honing and the sleeving BTW, im sure many other sleeve companies can as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stizzit »</TD></TR><TR><TD CLASS="quote">Chances are if you are going to put a new cap on it, you will HAVE to have it align honed which isn't really a big deal.
</TD></TR></TABLE> :trust me any compatant machine shop would be able to bring her back to life
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEKCivic »</TD></TR><TR><TD CLASS="quote"> :trust me any compatant machine shop would be able to bring her back to life
I'll assume you meant competent.
And you are correct however he is also having it sleeved so it only made sense
</TD></TR></TABLE>I'll assume you meant competent.
. a d a m
10
Aug 1, 2007 04:42 PM
Ryu
May 24, 2007 02:33 PM
Whitfield Inc.
21
Dec 31, 2005 12:51 PM
