BLOX don't fit at all...
Ok who has a pix of the Blox Turbo manifold with a t3/t4e on it on a Bseries engine???
Seems like they don't fit!!! even it the block is notched..
tried it on a LS and GSR block... to no avail!!!
don't say I don't know how to put a turbo on to!!!! LOL!!!
DOES NOT FIT!!!!
prove it by showing a pix.....a BIG debate about these manifold now...
When my friend brought over a REVHARD manifold and we bolted up the t3/t4e they fitted right up to the engine with plenty of room to spare.....NOT THE BLOX however!!! WE ARE CONfused!!! BIG TIME!!!
explanations???
DOES NOT FIT!!!!
explanations???
I just spok with people from inline four, asking if a b16a blox manifold will fit on a b18b. I thought they would because for one, the blox's being sold on ebay say that they will, and for two I've read that the exhaust ports on all b-series are the same. However, inline four told me that the two manifold are different..... So maybe you have the wrong one? Maybe it's for a b16??? Don't know for sure, but just trying to share some info.
The manifold was probably based on using either a 4 bolt or a 5 bolt turbo. Ie, if the manifold is designed for a 5 bolt turbo and you try to bolt a 4 bolt turbo onto it, good luck! To compound things, a 4 bolt with an S housing, you could be into the flywheel with all the grinding needed.
With the AC location, you can bolt a 5 bolt turbo to a 4 bolt manifold, but you will lose some downpipe-to-AC compressor clearance.
Manufacturers need to make things more aware of what turbos can and cannot be used(we are using ONLY 4 bolts for our AC kits).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 »</TD></TR><TR><TD CLASS="quote">
the manifold is made for a 5bolt. i have it in my b16. i will try to post some pics. i had to notch the block a lot though. LOL
well, since the manifold is a copy of inlinePRO...and inlinePRO, being a 5 bolt turbo manifold, I would think this manifold is the same.
Prepare to bust out the grinder and grind that block!
i have one on an ls/vtec no problems here just the wastegate sits right up against the valve cover thats all the problems i got no notching of the block turbonetics t3/t4 so it could just be that they fit perfect on an ls/vtec setup.
it wasn't a S-housing.. anyone using a S-housing usually uses the $700-$1300 manifold anyhow....MOST <------ok not everyone.....
and yes it was the 4bolt garretts...
yeah bro .... the 4bolt do NOT fit... beware guys... if you have a 5bolt then it is ok, but still have to trim alot of metal off at the/near the VIN number.......this sucks... we had to make adapter plates for 2 guys' cars already just to use these manifolds with NEW 4bolt GArrett turbo t3/t4e 57trimers....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecpower »</TD></TR><TR><TD CLASS="quote">yeah bro .... the 4bolt do NOT fit... beware guys... if you have a 5bolt then it is ok, but still have to trim alot of metal off at the/near the VIN number.......this sucks... we had to make adapter plates for 2 guys' cars already just to use these manifolds with NEW 4bolt GArrett turbo t3/t4e 57trimers.... </TD></TR></TABLE>
4 bolt turbos need a manifodl SPECIFIC for 4 bolt turbos ONLY. they have a diffrent configuration and set the turbo IN toawrds teh block more
hence you cannot use a 4 bolt turbo with a revhard./drag./inline pro manifold either unless you flip it the other way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecpower »</TD></TR><TR><TD CLASS="quote">guess 5bolts only will fit the BLOX......stupid how nothing is mentioned....dang it
Yea well, you'd think they'd mention the fact that a TiAL WG will *NOT* clear the head on a BLOX manifold/B18C either. Lovley..
</TD></TR></TABLE>Yea well, you'd think they'd mention the fact that a TiAL WG will *NOT* clear the head on a BLOX manifold/B18C either. Lovley..
Just flip the turbo so the compressor side is facing the drivers side. Not AC friendly at all, but I bet you could fit any turbo reguardless of its turbine housing being 4 or 5 bolts. Saying "Blox manis ONLY work with 5 bolt turbos" is not entirely true. If you want to keep AC, then I'd say it is.
Blue Hybrid
Oct 19, 2006 08:57 PM
mstolars
Jan 11, 2006 12:59 PM
