how to intall block gaurd myself?
Old Dec 6, 2004 | 08:54 PM
egvtec's Avatar
Default how to intall block gaurd myself?
i searched and didnt find my answer. i have been told to freeze it then put it in. also if i have to tap it on will it ovalize the sleeves? i need to know how to properly put it in. i am building my bottom end and i have honed the cylinder walls already.
Old Dec 18, 2004 | 08:02 PM
Beezer's Avatar
Default Re: how to intall block gaurd myself? (egvtec)
yeah someone help i need to know this too
Old Dec 18, 2004 | 09:22 PM
fknslmd's Avatar
Default Re: how to intall block gaurd myself? (Beezer)
i havent installed one but i do know you need to hone afterwards. i wouldnt use anymore force than tapping it with your hand, file it until it fits snug dont force it.
i wouldnt recommend freezing it though because when it expands in the block it will probably cause damage. i believe they're supossed to be flush with the deck also.
Old Dec 18, 2004 | 09:25 PM
boricuatuning's Avatar
Do not do this at home. It can be done but you can crack the gaurd and a sleeve. Also when you install the gaurd it pushes the sleeve in at the top, which is normal but must be honed by a machine shop to make the sleeve the same bore from top to bottom.
Old Dec 19, 2004 | 03:33 PM
NJIN BUILDR's Avatar
Default Re: how to intall block gaurd myself? (boricuatuning)
Repeat-Do not do this at home!!You can't believe how much the things distort the bores.If someone really wants one I usually hone to the next oversize.
Glenn
Old Dec 20, 2004 | 11:53 AM
tgreaves's Avatar
Default Re: how to intall block gaurd myself? (NJIN BUILDR)
Block guards are just like any other block modification.. You should take it to a machine shop to have it installed.. They modify the block guard to fit into your motor not make your motor work with the block guard..
Old Dec 20, 2004 | 01:00 PM
RyanEJ8's Avatar
LOTS of misinformation in this thread. The blockguard does not need to be machined to fit. It is simply file fit. If you don't slam a hammer on it, it's not going to distort the sleeves.
Old Dec 20, 2004 | 01:02 PM
tgreaves's Avatar
Default Re: how to intall block gaurd myself? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">LOTS of misinformation in this thread. The blockguard does not need to be machined to fit. It is simply file fit. If you don't slam a hammer on it, it's not going to distort the sleeves.</TD></TR></TABLE>
Your right, there is alot of misinformation in this thread.. Anything that touches the cylinder walls will distort it.. I have seen a few block guards fail but none that were professionally installed failed..
vtechjunkie
May 10, 2009 02:49 PM
boostedteg4dr
Apr 6, 2009 03:30 PM
IndySporty
Jan 27, 2007 07:36 PM
TypeR0207
Jan 21, 2002 09:25 AM
