Throttle body
Old Dec 6, 2004 | 05:49 PM
return_2020's Avatar
Default Throttle body
this is 03 civic ex. manual trans. today i opend up the air filter box (it stock) and tried to look inside the throttle body. as soon as i open up the throttle plate inside and put my finger in, i found black color dust inside with little greasy stuff. its inside on a little top part, other than that its clean inside. what is it ? is it suppose to be like that or i should clean it ? how do i clean it. it has only 30k miles. please advise.
Old Dec 6, 2004 | 05:50 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Throttle body (return_2020)
Brake-clean and a rag, dude. It's just gunk (oil and dust) that builds up in there after a while. Nothing to be concerned about.
Old Dec 6, 2004 | 05:58 PM
hondainspired's Avatar
well if theres oil it could be ur PCV valve... i know that i've heard those little tornado things make a black soot in the intake...
Default Re: Throttle body (hondainspired)
what you mean PCV valve ? is it something to be worried about ? or i should clean it
Old Dec 6, 2004 | 06:08 PM
welll i was thinkin at 30k ... i dout its really malfunctioning... but its possible.... PCV= positive crankcase ventilation .... like $10 bucks tops... and it lets the motor (or top end specificly) breath through the intake and doesn't let any oil into the intake...
EDIT: 1100th POST!!! suposedly ur supose to shake it and if it doesn't make a noise like a lil ball shaking inside then its no good...
Old Dec 6, 2004 | 06:09 PM
k got u. so you are saying htat i should replace it or clean the throttle body ?
Old Dec 6, 2004 | 06:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by return_2020 &raquo;</TD></TR><TR><TD CLASS="quote">k got u. so you are saying htat i should replace it or clean the throttle body ?</TD></TR></TABLE>
check the valve first and clean the throttle body first...
Old Dec 6, 2004 | 06:13 PM
what and how should i check it ? sorry bro. tring to learn things here
joenobodyyet
Honda Civic (2006 - 2015)
Nov 1, 2018 12:47 PM
RA21625
Jul 24, 2015 05:57 AM
BLKFLSH
Sep 22, 2009 05:49 PM
snapper1978
Oct 10, 2006 08:26 AM
Gump
Apr 18, 2002 12:51 PM
