I NEED HELP FAST.. PLS
Old Dec 6, 2004 | 04:35 PM
l e o h j's Avatar
Default I NEED HELP FAST.. PLS
i recently adjusted my valve clearance, but when i tried to start it..
the check engine light stays on.. and the ecu gives me 10 short blinks anyone knows what the problem is.. it would help me alot!!
pls help!! i need help fast.
thanks in advance!
Old Dec 6, 2004 | 04:38 PM
mr. carpenter's Avatar
Default Re: I NEED HELP FAST.. PLS (leohj)
IAT sensor
Old Dec 6, 2004 | 04:43 PM
l e o h j's Avatar
Default Re: I NEED HELP FAST.. PLS (mr. carpenter)
where is that located??
o yea, after adjusting no.2 valve do i put the "up" mark again in 12 o clock position?
Old Dec 6, 2004 | 05:26 PM
o2 sensor is the sensor that goes into you exhaust manifold. i do not know about the valves.
Old Dec 6, 2004 | 06:18 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
IAT is white 2 pin sensor on #1 runner for d16a6
Old Dec 6, 2004 | 06:24 PM
Kasper.'s Avatar
Default Re: (mike_belben@yahoo.com)
does the car start and idle smoothly?
Old Dec 7, 2004 | 09:16 AM
l e o h j's Avatar
Default Re: (Kasper.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kasper. &raquo;</TD></TR><TR><TD CLASS="quote">does the car start and idle smoothly? </TD></TR></TABLE>
no.. i think the valve clearance adjustment is wrong..
i might adjust it again..
Old Dec 8, 2004 | 08:17 AM
l e o h j's Avatar
ok everything is running fine now..
the reason why my check engine was on..my IntakeAirTemperature Sensor was disconnected.. and i had a friend adjust my valve clearance. so everything is ok now.. whew!
thanks for all who left a comment tho
potatointegra01
Jun 24, 2015 12:52 PM
boostin4door
Oct 19, 2003 02:32 PM
thehondaguru
Jun 28, 2003 12:09 AM
AprilzWarrior
Nov 4, 2002 05:19 PM
