horn not working...
Old Dec 6, 2004 | 03:17 PM
sinfulj32's Avatar
Default horn not working...
alright so all of a sudden my horn wasnt working one day... i knew because my stock alarm horn didnt sound when i locked it...i checked my fuses and their not blown...when you press the horn button you could hear the relay clicking so its not the relay....what do you think its is....
sinfulj32's Avatar
Default Re: horn not working... (eeveeayen)
by the way i have a 99ex coupe
Old Dec 6, 2004 | 03:18 PM
Kamin's Avatar
sure its plugged in?
Old Dec 6, 2004 | 03:23 PM
sinfulj32's Avatar
Default Re: horn not working... (Kamin)
yeah
Old Dec 6, 2004 | 04:30 PM
dantastic's Avatar
unplug the horn and test for voltage at the horn when the button is pressed..... simple trouble shooting
Old Dec 6, 2004 | 04:33 PM
jlacoy82's Avatar
71.192.16.183
Default Re: horn not working... (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">unplug the horn and test for voltage at the horn when the button is pressed..... simple trouble shooting </TD></TR></TABLE>
If voltage at the horn, the horn is probably dead. I'm assuming the stock horn is just your average compression driver horn of sorts?
Old Dec 6, 2004 | 04:55 PM
GdmLaz's Avatar
same problem here and basically all u need is a new horn
Old Dec 6, 2004 | 05:27 PM
stripes777's Avatar
Default Re: (Slammed92hbonN20)
ya mine has been this way for a long time now too. i can hear the clicking under the steering column but the horn doesnt work. it works once a month, for 10 seconds, lol. then it sorta has to recharge. i sorta wanna get those loud ones at autozone and hook those babies up. anyone got those?
Old Dec 13, 2004 | 07:16 AM
ebelp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eeveeayen &raquo;</TD></TR><TR><TD CLASS="quote">when you press the horn button you could hear the relay clicking so its not the relay....</TD></TR></TABLE>
I thought that if it clicks, that means the relay is bad...?
Old Dec 13, 2004 | 07:20 AM
AutoXer's Avatar
Default Re: (stripes777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 &raquo;</TD></TR><TR><TD CLASS="quote"> i sorta wanna get those loud ones at autozone and hook those babies up. anyone got those? </TD></TR></TABLE>
I've got the Hella Supertones. Awesome horn. Insallation was very easy. Splice the wire going to the horn, run a wire for ground for the two hellas, then mount them both to the stock location with the stock bolt. Took me about 1/2 hour to do, just because I'm all crazy about wiring properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> thought that if it clicks, that means the relay is bad...? </TD></TR></TABLE>
Relays click when they switch. That means it's working / getting power. Check to see if you have voltage at the horn, and you'll be able to tell if the horn is working or not.
Old Dec 13, 2004 | 08:26 AM
Ghetto Civic HX's Avatar
I love to drive
Default Re: (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
I've got the Hella Supertones. Awesome horn. Insallation was very easy. Splice the wire going to the horn, run a wire for ground for the two hellas, then mount them both to the stock location with the stock bolt. Took me about 1/2 hour to do, just because I'm all crazy about wiring properly.</TD></TR></TABLE>
So then could I wire a horn from like a Crown Vic to my car. The stock civic horn is pretty weak, and doesn't do much to get people's attention. I've been thinking for a while that a horn from another car would help a lot.
Old Dec 13, 2004 | 08:38 AM
AutoXer's Avatar
Default Re: (Ghetto Civic HX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghetto Civic HX &raquo;</TD></TR><TR><TD CLASS="quote">
So then could I wire a horn from like a Crown Vic to my car. </TD></TR></TABLE>
If they're switched / powered the same, then yes it'll bolt right up. If not, you may have to throw in a relay or something.
Old Dec 13, 2004 | 08:47 AM
I love to drive
Cool, thanks.
jmeyer99
Apr 28, 2010 02:13 PM
BlueIntegraBoy
Oct 20, 2006 05:38 PM
xkrntamax
May 31, 2006 07:48 PM
r1de4life
May 3, 2006 07:29 PM
ITR43
Feb 13, 2006 07:09 PM
