*** 2.5" or 3" DP ??? ***
Old Dec 5, 2004 | 10:01 PM
jfoster's Avatar
Default *** 2.5" or 3" DP ??? ***
I am planning to run a turbo LS/Vtec with pistons and rods (not sleeved) and hope for 350-400whp with Hondata.
SC34 turbo
Spearco FMIC
Hondata S200B
RC 550s
BLOX Mani
I was planning to run a 3" AC compliant DP with 3" cat and exhaust. But I was recently told that a 2.5" would make about the same power and that I would reach full boost sooner and that it would have more low end. And that would be better for take offs as its a daily driver.
Agree or no?
Old Dec 5, 2004 | 10:09 PM
crex23's Avatar
Default Re: *** 2.5" or 3" DP ??? *** (jfoster)
Your turbo will spool quicker with a 3" dp. I would go 3" with your hp goals
Old Dec 5, 2004 | 10:28 PM
pimpintyperintegra's Avatar
bigger downpipe and exhaust=better spool and more power
go with the 3" definitely
also I have some Eagle rods for an LS for sale never used make an offer if interested
Old Dec 6, 2004 | 11:58 AM
RyanEJ8's Avatar
3" > 2.5"
Anyone that tells you otherwise is WRONG.
Old Dec 6, 2004 | 12:31 PM
*Boostwerks*'s Avatar
The bigger the better.
Thats also...what she said. lol.
Old Dec 6, 2004 | 12:44 PM
jfoster's Avatar
Default Re: (Bryson)
Ok, I am set on 3". Which sucks because I just found a slightly damaged (I have a welder to repair it) 2.5" DP for like $50....but a new 3" AC compliant one is $240...
Ok, I realize crushbend sucks...but would 3" crushbent be better than 2.5" mandrel ??? hmmm....
Old Dec 6, 2004 | 04:59 PM
i would not use anything crush bent
as far as i'm concerned it is no good
mandrel is the way to go
Old Dec 6, 2004 | 05:52 PM
Rory Breaker's Avatar
Default Re: (jfoster)
I would say the difference is negligble...and not just because Im selling the DP
Bigger is better, but for your setup, I dont see 2.5" being a huge issue.
Old Dec 6, 2004 | 05:58 PM
oxSLEEPERxo's Avatar
Default Re: (newgsrdriver)
crush bent will restrict some flow, stick with mandrel bent
Old Dec 6, 2004 | 06:52 PM
Turbo E's Avatar
hell if a 4" fits use that instead.
Old Dec 6, 2004 | 07:13 PM
ooairewreckoo's Avatar
question for all you guys.
If the turbine housing is only 2.5 outlet why would a person need a 3inch? would the numbers really be significantly higher? Yes bigger is better but is it logical?
iv'e got a gt35r with a 2.5 outlet. my shop says that a 3inch dp really wouldnt make a difference because the turbo is only 2.5.
Old Dec 6, 2004 | 07:23 PM
japrex's Avatar
no that is definatly not true. usually on exhaust bigger does not always mean better but on a turbo application bigger IS better. 3" for sure no doubt!
carlos8
Oct 26, 2011 05:16 PM
thumper64
Jan 12, 2010 10:40 PM
Rooftop voter
Feb 28, 2007 05:23 PM
Ak_ef9
Oct 7, 2006 08:40 PM
riceball777
Mar 11, 2006 11:48 PM
