Grinding sound when starting
Old Dec 5, 2004 | 08:32 PM
JDM H22's Avatar
Default Grinding sound when starting
When I start my car sometimes it makes a grinding noise. It does not do it when its cold and the starter was new had it replaced under warranty again just to make sure. Its a JDM H22 but the starte is USDM. Iam pretty sure that does not matter though. Anybody have this problem before?
Old Dec 5, 2004 | 08:59 PM
digitalh3lix's Avatar
Default Re: Grinding sound when starting (JDM H22)
same ***** happening to me, ppl are tellin me its my belts... ethier alternator or power steering? it doesnt always happen tho.. thats the weird part.
Old Dec 5, 2004 | 09:31 PM
fastwanabe's Avatar
my guess would be the starter and or flywheel.
Old Dec 5, 2004 | 10:05 PM
xbn83's Avatar
If it is belt problem, the sound should be screeching, not grinding. I had similar grinding sound like that b4 when I started the car (just sometimes only). I found out the the 1 of the wire connector to the starter loose, it was connected but not all the way in, loose. I just pluged it tight and the problem solved. I don't know exactly what is wrong with your case. I 'm just sharing mine, hope it will help somehow.
Old Dec 6, 2004 | 12:07 AM
@ries's Avatar
maybe the ring gear has moved on the flywheel. happened to me a while back. it sounded like crap. metal on metal grinding.
Old Dec 6, 2004 | 04:20 AM
ludegetsmwet's Avatar
Default Re: Grinding sound when starting (@ries)
i would think it could be the flywheel. is it a stock flywheel or are there a few miles on it. Teeth could have got rounded over
Old Dec 6, 2004 | 07:25 AM
staticrex's Avatar
Default Re: Grinding sound when starting (ludegetsmwet)
I get a metallic sound on start up as well. It usually lasts until the car warms up, 2-3 minutes. Also it makes the same noise when I engage a higher gear with a low rpm. Say like going into 4th at like 2500rpm.
Maybe this is my flywheel too?
Old Dec 6, 2004 | 09:30 PM
JDM H22's Avatar
Thats what I thought and hoped it was when I got a new clutch, so I replaced the flywheel. Seemed to be fixed until 9th or 10th start. But sometimes it starts good that many times in a row,if I am lucky.
Cay-DC2
Nov 13, 2010 07:46 AM
meanshyguy
Sep 1, 2009 07:42 PM
blakacintegra
Nov 7, 2007 01:16 PM
Paste
Sep 20, 2004 01:18 PM
Gedupsound
Oct 4, 2003 01:56 PM
