ITR Problem
Old Oct 21, 2010 | 04:51 PM
Cay-DC2's Avatar
Default ITR Problem
Hi guys,
I have a problem with my Type R. About a week ago I noticed a sound coming from my engine bay while I was starting the car, to me, it sounded like the brushes were going bad in the starter, so I drove like that for a few days until the sound kept getting louder and the car even hesitated to start at times. I also noticed that this sound could be heard while the car is idling if I rev it a tiny bit, it sounds like a metal to metal scraping noise.
I got a new starter, installed it, same thing happens. So I'm pretty sure I got a new starter for no reason, I never even bothered to take a look @ the old one.
It has gotten basically so bad that when I try to start the car it won't start most of the time, I hear the starter spinning but I still hear this loud weird noise that sounds like metal brushes or something scraping against something (that's the only way I can explain it).
Only other thing I can think of is something is wrong with the teeth on the flywheel or anything, what do you guys think? The car was driving normal btw. It push starts fine also.
Old Oct 21, 2010 | 08:37 PM
Cay-DC2's Avatar
Default Re: ITR Problem
This can be closed.
The ring gear is spinning on the flywheel, so I'm pretty sure that's the problem lol.
Old Oct 22, 2010 | 04:53 AM
blown_ss's Avatar
Originally Posted by Cay-DC2
This can be closed.
explain? what do you mean the ring gear is spinning on the flywheel?
Old Oct 22, 2010 | 08:14 AM
Cay-DC2's Avatar
As in its basically seperated. You try to turn the flywheel by sticking a screwdriver between the teeth but the only thing spenning is the teeth and nothing else.
Old Oct 22, 2010 | 11:37 AM
SOHCunderdog's Avatar
LOL which what brand flywheel is this?
Also who you is? (Assuming you're from GCM)
Old Oct 22, 2010 | 11:52 AM
Spunkster's Avatar
do you have an aftermarket flywheel, or do you have a 2 piece flywheel? If you have a one piece flywheel then it sounds more like your flywheel bolts have come loose which could mean much more serious problems.
Old Oct 22, 2010 | 03:17 PM
Cay-DC2's Avatar
It's a stock flywheel lol.. I don't think the flywheel bolts came loose though.
This is Aj btw.
Cay-DC2's Avatar
This is Aj btw.
Old Oct 22, 2010 | 03:22 PM
Zeen. This is Jason. I have a stock flywheel if you need one.
Old Oct 22, 2010 | 03:26 PM
Tyrant_007's Avatar
Does it keep making the sound when you press in the clutch? Can you take a short video (with sound) and put it on youtube?
Old Oct 22, 2010 | 03:32 PM
Cay-DC2's Avatar
The starter is off and I can't bother putting it back on now, but the sound was the ring gear spinning around on the flywheel I assume, when I pull the tranny I'll take pics and make a video of it so you can see.
Old Oct 25, 2010 | 12:42 PM
Spunkster's Avatar
An oem flywheel is ONE peice and there is no separate ring gear. With an OEM flywheel the only thing that would allow it to turn is if the flywheel bolts that hold it to the crank have backed off or sheared off.
Old Oct 26, 2010 | 06:07 PM
Cay-DC2's Avatar
Well I'm not sure then but take a look @ this. Notice only the teeth are spinning and towards the end everything starts spinning.
http://www.youtube.com/watch?v=2zHVmiGWaGw
Let me know your thoughts.
Old Oct 27, 2010 | 08:55 AM
lsturbo33's Avatar
Crazy^^ I've never seen that happen before.
Old Oct 27, 2010 | 06:49 PM
Cay-DC2's Avatar
Anyone else?
Old Oct 28, 2010 | 03:13 PM
Looks like you found the sweet spot right at the end of the video.
Thanks for confirming my thoughts about if that could ever happen.
Old Oct 28, 2010 | 06:27 PM
Cay-DC2's Avatar
But I never even knew it could happen with the stock flywheel.
Anyone else experience this before?
Old Oct 30, 2010 | 10:36 AM
Cay-DC2's Avatar
Bump
Old Nov 6, 2010 | 11:29 AM
Cay-DC2's Avatar
It was the ring gear.
I took it right off the flywheel.
http://www.youtube.com/watch?v=FfdRJmEu6nQ
Old Nov 8, 2010 | 05:46 AM
Dave-ROR's Avatar
Have not seen that one before. Nice find.
Old Nov 9, 2010 | 05:00 AM
You sure thats the stock flywheel bro? Looking at the stock flywheel I took out it looks like one solid piece.
Old Nov 13, 2010 | 06:09 AM
Cay-DC2's Avatar
If its aftermarket it looks a lot like stock + its a very heavy aftermarket lol...
Don't mind my toes lol
Old Nov 13, 2010 | 07:06 AM
vtec2nv's Avatar
I had the sameeeee problem with a stock flywheel. Maybe its not common, but it does happen to stock oem flywheels.
Old Nov 13, 2010 | 07:46 AM
JDM Like Whoa's Avatar
I've had it happen to my stock one but on my jdm itr motor, although it's not very common .
VFR
Aug 17, 2016 03:38 PM
blakacintegra
Nov 7, 2007 01:16 PM
Tad
Feb 23, 2007 11:22 PM
Gedupsound
Oct 4, 2003 01:56 PM
