for all of the boosted h22's
my freind has an h22 swap he's about to boost.
we're wondering if the stock fpr's are weak? he has a high pressure walbro 255 fuel pump. he's going to be running around 15-17psi (on a built/sleeved motor) also should he get a fuel rail too or will the stock one be ok?
what brand fpr's are good? i heard aem sucks
what brand fuel rail?
This isnt rocket science, there isnt 10000psi going through a fuel rail,
therefore any rail will be fine. aem, str, venom, im sure obx has one out there.
As far as fitment though, i can only recommend aem to you since i have it with zero problems.
I dont know about fpr's, I doubt the aem one sucks THAT bad. If any of them suck its the b&m.
therefore any rail will be fine. aem, str, venom, im sure obx has one out there.As far as fitment though, i can only recommend aem to you since i have it with zero problems.
he plans on making around 500-550 whp, i know pretty much all fuel rails are the same, would the stock one be ok? anyone have any insight on the fpr issue
aeromotive 1:1 fpr and an AEM rail, thats what i run on my h22 turbo setup thats built for about the same power as your friend is aiming for, thats a pretty high goal, what kind of turbo does he have?
The AEM or any other aftermarket fuel rail won't make any different than the stock one, it is just a waste of money. Trust me on this! Stock fuel rail is just fine. I have AEM fuel pressure regulator and it is suck a$$. I have it on the car about a year. I have to re-adjust the fuel pressure every couple weeks, because the pressure jumps up couple psi slowly by itself over the time. Right now the diaphragm inside the regulator is so messed up. It makes the psi not accurate anymore. I will put back the stock one soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 »</TD></TR><TR><TD CLASS="quote">The AEM or any other aftermarket fuel rail won't make any different than the stock one, it is just a waste of money. Trust me on this! Stock fuel rail is just fine. I have AEM fuel pressure regulator and it is suck a$$. I have it on the car about a year. I have to re-adjust the fuel pressure every couple weeks, because the pressure jumps up couple psi slowly by itself over the time. Right now the diaphragm inside the regulator is so messed up. It makes the psi not accurate anymore. I will put back the stock one soon.</TD></TR></TABLE>
yeah i heard aem fpr's suck too. anyone have any expierence with any other brands?
I've had mine for over 2 years now and haven't had an issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 »</TD></TR><TR><TD CLASS="quote">"94 accord built h23 460whp 400wtq @ 20.75psi" on a stock fuel rail and fpr... Hopefully that is all you guys need to know...</TD></TR></TABLE>
'nuff said...
'nuff said...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fafsa »</TD></TR><TR><TD CLASS="quote">
im pretty sure he'll need an aftermarket fpr with the walbro 255. what other brands has anyonle else have any expeirence with?</TD></TR></TABLE>
yeh i run the walbro 255 and i do plan on seeing over 500whp after i turn my boost up to 28psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW »</TD></TR><TR><TD CLASS="quote">my freind has an h22 swap he's about to boost.
500WHP on 15-17 psi Highly unlikely
Originally Posted by DFW
he plans on making around 500-550 whp, i know pretty much all fuel rails are the same, would the stock one be ok? anyone have any insight on the fpr issue</TD></TR></TABLE>(on a built/sleeved motor) also should he get a fuel rail too or will the stock one be ok?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 VTEC »</TD></TR><TR><TD CLASS="quote">500WHP on 15-17 psi Highly unlikely</TD></TR></TABLE>
No, it's not. What just IS psi? Not too relevant.
i use sx
.if your friend has spent the money on the bottom end
"generally speaking" why not do the fuel system right to
.i run 2 fuel pumps
one for the motor and one for the pro race fogger set up
,each system is reg
.i am looking for over 700 hp w/just the turbo.this car will be out at the first of summer,and i will have pics and dyno sheets also,wish me luck?
3/4 deck plated 2.6L h22 w/t-74 bb and pro race fogger
coming to a dyno near you very soon.
.i run 2 fuel pumps
,each system is reg
.i am looking for over 700 hp w/just the turbo.this car will be out at the first of summer,and i will have pics and dyno sheets also,wish me luck?3/4 deck plated 2.6L h22 w/t-74 bb and pro race fogger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 VTEC »</TD></TR><TR><TD CLASS="quote">(on a built/sleeved motor) also should he get a fuel rail too or will the stock one be ok?
what brand fuel rail?</TD></TR></TABLE>
500WHP on 15-17 psi Highly unlikely[/QUOTE]
haha, like car_boy_16 said, amount of psi doesnt matter. there are many factors are mixed into this, like what size turbo your using, ect..
Nope. If you have a standalone (like you SHOULD if you're pushing major HP) then you can simply tune down the injector's pulsewidth to decrease the amount of fuel being sprayed into the combustion chamber.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus »</TD></TR><TR><TD CLASS="quote">
Nope. If you have a standalone (like you SHOULD if you're pushing major HP) then you can simply tune down the injector's pulsewidth to decrease the amount of fuel being sprayed into the combustion chamber.</TD></TR></TABLE>
ding ding ding.. the man is right, stock rail and fpr are fine, hell im using a civic fuel rail on my boosted prelude./
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW »</TD></TR><TR><TD CLASS="quote">i didnt know aeromotive made fpr's for h22's? is this hp # possible on stock fuel rail? oh and he has a sc63</TD></TR></TABLE>
Its a generic system, 6AN fittings, it will work with stock fuel lines and fuel filter if you want to though, I used to have it connected to my stock fuel filter
DA TeG 90
Jan 27, 2010 03:10 PM
