Turn Signal, Speedo, and tach dont work
Old Dec 5, 2004 | 05:31 PM
RedStar101's Avatar
Default Turn Signal, Speedo, and tach dont work
I figured out that it was a fuse under the dash thanks for you help guys
ps the jdm corners were not the right size even anyone want some jdm corners either for a 4 door or coupe i dont know which one if varys
Modified by RedStar101 at 3:05 AM 12/6/2004
Old Dec 5, 2004 | 05:33 PM
Daniel_san's Avatar
Default Re: Turn Signal, Speedo, and tach dont work (RedStar101)
since when does installing clear corners require rewiring ?
Old Dec 5, 2004 | 05:34 PM
Ricey McRicerton's Avatar
Default Re: Turn Signal, Speedo, and tach dont work (Daniel_san)
It's cause they're the JDM ones! They gotta be rewired all RHD style!
In all seriousness, just start checking fuses.
Old Dec 5, 2004 | 05:36 PM
RedStar101's Avatar
Default Re: Turn Signal, Speedo, and tach dont work (Ricey McRicerton)
i did a pretty good visual look through on all the fuses and i could not see a blown one i had to cut the wire and re splice it to the jdm one since it was cut that is why i had to them open but do you kno if the fuse is under hood or the dash fuses?
Old Dec 5, 2004 | 05:37 PM
Most likely under the dash. There are only a few underhood fuses and I don't believe that the corners or speedo is attached to any of them (I've managed to destory damn near all of the underhood ones, including the main fuse).
Old Dec 5, 2004 | 05:38 PM
RedStar101's Avatar
would it be the turn signal relay causing my problems? or would it most likely be a fuse?
Old Dec 5, 2004 | 05:40 PM
hatchi's Avatar
most likely a fuse
Old Dec 5, 2004 | 05:42 PM
RedStar101's Avatar
Default Re: Turn Signal, Speedo, and tach dont work (hatchi)
does anyone know the exact fuse that controls the speedo, tach, and signals?
Old Dec 5, 2004 | 05:44 PM
Redline96LX's Avatar
* B A N N E D *
well i mean its lights. you just used bare wire to connect right? same connection as your OEM lights? if thats the case, a blown fuse can be the only problem/
Old Dec 5, 2004 | 05:47 PM
RedStar101's Avatar
Default Re: Turn Signal, Speedo, and tach dont work (Redline96LX)
but does anyone know the location of the fuse?
Old Dec 5, 2004 | 05:49 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Been through this a few times because I didn't want to unplug my battery when I was testing out a cluster swap. Check your wiring make sure everything is secure and not touching then go through and check your under dash fuses. I cannot give you an exact one as it's cold outside, just go through and individually check your fuses to the hazards and turn signals. And replace, it's always fixed my negligence to want to unplug the battery.
EM2_PLo
Honda Civic (2001 - 2005)
Jul 19, 2010 12:54 PM
jdmhagengsr
Sep 24, 2006 09:30 AM
O16581724 5 2 5
Oct 6, 2005 10:03 PM
TimithI
Sep 13, 2002 10:04 AM
