Turn Signal, Speedo, and tach dont work
I figured out that it was a fuse under the dash thanks for you help guys
ps the jdm corners were not the right size even anyone want some jdm corners either for a 4 door or coupe i dont know which one if varys
Modified by RedStar101 at 3:05 AM 12/6/2004
Re: Turn Signal, Speedo, and tach dont work (Daniel_san)
It's cause they're the JDM ones! They gotta be rewired all RHD style!
In all seriousness, just start checking fuses.
Re: Turn Signal, Speedo, and tach dont work (Ricey McRicerton)
i did a pretty good visual look through on all the fuses and i could not see a blown one i had to cut the wire and re splice it to the jdm one since it was cut that is why i had to them open but do you kno if the fuse is under hood or the dash fuses?
Re: Turn Signal, Speedo, and tach dont work (RedStar101)
Most likely under the dash. There are only a few underhood fuses and I don't believe that the corners or speedo is attached to any of them (I've managed to destory damn near all of the underhood ones, including the main fuse).
would it be the turn signal relay causing my problems? or would it most likely be a fuse?
Re: Turn Signal, Speedo, and tach dont work (hatchi)
does anyone know the exact fuse that controls the speedo, tach, and signals?
* B A N N E D *
1 Post
well i mean its lights. you just used bare wire to connect right? same connection as your OEM lights? if thats the case, a blown fuse can be the only problem/
Location: Why so you can pretend like youre interested, FL/OK
Been through this a few times because I didn't want to unplug my battery when I was testing out a cluster swap. Check your wiring make sure everything is secure and not touching then go through and check your under dash fuses. I cannot give you an exact one as it's cold outside, just go through and individually check your fuses to the hazards and turn signals. And replace, it's always fixed my negligence to want to unplug the battery.
O16581724 5 2 5
10-06-2005 10:03 PM
