spark plug gap with msd
Old Dec 5, 2004 | 03:12 PM
hondaeg8's Avatar
Default spark plug gap with msd
whats a good gap to set my spark plugs at when using an msd sci ignition kit?
i will be using the ngk spark plugs on a jdm gsr motor.
Old Dec 5, 2004 | 03:59 PM
ISawUL00k's Avatar
Default Re: spark plug gap with msd (hondaeg8)
i think it is 35-40... get a book. $15.00 at kragens
Old Dec 5, 2004 | 04:09 PM
hondaeg8's Avatar
Default Re: spark plug gap with msd (ISawUL00k)
stock gap is .044
Old Dec 8, 2004 | 04:01 PM
hondaeg8's Avatar
anyone else?
Old Dec 8, 2004 | 04:07 PM
DAguyLS's Avatar
yea .44
anywhere within 5 hundredths of the stock gap will work just fine
i think it's 1.1mm also, incase that helps
Old Dec 8, 2004 | 04:13 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (slamdcivic)
yep a .050 gap would wok well with that MSD setup. which is about 1.25mm.
Old Dec 8, 2004 | 07:23 PM
hondaeg8's Avatar
Default Re: (00Red_SiR)
so whats the difference between running a smaller gap and a bigger gap?
Old Dec 8, 2004 | 08:18 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (hondaeg8)
you typically want to run a smaller gap if you're running boost or nitrous often. This makes it easier to ignite the plug and the mixture which is harder to ignite when it's compressed. A larger gap on a NA motor will give you more power and better gas mileage, but it's normally limited by the weak stock ignition as to how wide you can go. Running a MSD will allow you to increase the gap.
hondaeg8
Dec 12, 2003 10:29 PM
B20-T
Jun 9, 2003 03:58 PM
SIK IN DA HED
Aug 13, 2002 02:43 PM
Type R 702
Mar 7, 2002 12:01 PM
batboy18
Dec 15, 2001 06:28 PM
