my tranny wont shift into 2nd, 4th, or reverse.....
well i finally got my car running. come to find out my gsr hydro tranny wont shift into 2nd, 4th, or reverse. 1,3,5 work fine. 2,4 reverse i can kinda move the shifter to where the gear should be, but it wont go in. it doesnt really grind, it just kinda feels like the gear isnt there. is it possible to have broken something internally, or is it something small like i need to have my linkage re-aligned...i need my car to work, because my other car **** the bed, so any help is appreciated
Modified by blackeg at 1:03 AM 12/12/2004
Modified by blackeg at 1:05 AM 12/12/2004
Modified by blackeg at 1:07 AM 12/12/2004
Modified by blackeg at 1:10 AM 12/12/2004
try inspecting the shaft going from the shifter back to the tranny. i'ts more like a support brace.... mine came disconnected from the tranny there and i had the same problem...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteGraGSR »</TD></TR><TR><TD CLASS="quote">try inspecting the shaft going from the shifter back to the tranny. i'ts more like a support brace.... mine came disconnected from the tranny there and i had the same problem...</TD></TR></TABLE>
ok ill give that a look. any other ideas?
ok i put my stock civic shifter back in, and it helped a little, but i still have the same problem. what else can i look for??? bump!
I doubt its your clutch since 1-3-5 work fine. It could be a problem with your linkage or bushings interfereing some how. I would check all bolts and bushings between the shifter and the tranny to start and see what you come up with.
Aren't 2nd, 4th, and reverse gears on the same shaft inside the tranny? Could be a problem with the forks that engage that particular gearset inside the tranny. If everything outside the tranny looks okay (linkages and stuff) then I think you will probably need to just get a different tranny, unless you want to tackle opening it up, finding the actual problem, and then replacing the necessary internal parts.
getting inside that tranny sucks *****.... i had to swap cases a while back... theres a bearing on the end of the shaft ull have to press off... good luck, u will need it
I bet it's outside.
1st & 2nd share the same synchro hub & shift fork with each other.
3rd & 4th share the same hub & fork.
Not only that, but the 3/4 hub is on the mainshaft, the 1/2 hub is on the countershaft.
Reverse doesn't even have a synchro.
I'm guessing the shift linkage is hitting something when you try to move the lever back. (2, 4, & R are back...) Or that fixed rod in the linkage is coming loose.
is it possible my linkage just needs to be re-aligned, or like my shift fork or something is just out of alignment? the linkage was on the tranny when i transported it a few times, and might have been bumped around....
When you move the lever back, it pushes the shift rod into the tranny. Is something in the way (exhaust)? Is something bent that's preventing it from going that way?? Watch the action of that linkage while someone's inside working the shift lever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">When you move the lever back, it pushes the shift rod into the tranny. Is something in the way (exhaust)? Is something bent that's preventing it from going that way?? Watch the action of that linkage while someone's inside working the shift lever.
we looked, and it didnt hit anything. i wonder if my linkage is just a hair too short, like too short to put it into gear fully?
Edit: jesus, another thread from 2004, this is getting annoying.
I had the same problem, did an auto to manual swap and discovered that the new boot I put on the tranny/shift rod was interfering with the shift rod where is goes into the tranny. It is a pain in the butt to remove the shift rod so I just cut the boot off and I am going to make one out of an old bike inner tube.
I have a 91 prelude with the same problem I just put a new motor in same a stock I but I thank it was a automatic motor and it's cable shift I have tried to a just it and tried changing them. Any ideas?
Did u ever figure out what the problem was???? PLEASE HELP my tranny is doing the same thing and its driving me crazy!!!!!!!!
DA-MAX
Oct 26, 2006 03:05 AM
jetpilot
Dec 1, 2004 02:49 PM
