type r sway bar? eg hatch?
Old Dec 4, 2004 | 03:24 PM
TriniTech's Avatar
Default type r sway bar? eg hatch?
i got a hold of 2001 integra type r front and rear sway bars and tie bars, will they fit my 92 eg si hatch?
Old Dec 4, 2004 | 03:50 PM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: type r sway bar? eg hatch? (TriniTech)
As long as your car came from the factory with sway bars, if not your going to need to replace your factory LCA's
LOL I didn't see that your car was an SI, yes those parts will fit
Old Dec 4, 2004 | 03:51 PM
jaM3s Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TriniTech &raquo;</TD></TR><TR><TD CLASS="quote">i got a hold of 2001 integra type r front and rear sway bars and tie bars, will they fit my 92 eg si hatch?</TD></TR></TABLE>
Yes.
Look into a beaks kit also.
If your SI did NOT come with sway bars then you will need new LCA's
Old Dec 4, 2004 | 04:04 PM
93_hatch's Avatar
Default Re: type r sway bar? eg hatch? (James Bond)
i have an Si also and was thinking about goin ITR sway bars but my SI didnt come with a rear sway bar but it look like holds and all ready i am not to sure. how could i know for sure that i can put the ITR with out new lower control arms
thanks
Old Dec 4, 2004 | 04:09 PM
jlacoy82's Avatar
71.192.16.183
Default Re: type r sway bar? eg hatch? (93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i have an Si also and was thinking about goin ITR sway bars but my SI didnt come with a rear sway bar but it look like holds and all ready i am not to sure. how could i know for sure that i can put the ITR with out new lower control arms
thanks</TD></TR></TABLE>
If theres an extra pair of holes on your LCA.
Old Dec 4, 2004 | 05:20 PM
93CivicSI's Avatar
Insure that the front sway has the same type of sway bar bushing assemblies. - some are straight through, some have a 90 degree bend....
The two are not interchangable.
Old Dec 4, 2004 | 07:00 PM
93_hatch's Avatar
Default Re: type r sway bar? eg hatch? (93CivicSI)
coo thanks i will check it tmr
Old Dec 4, 2004 | 08:56 PM
TriniTech's Avatar
Default Re: type r sway bar? eg hatch? (92 civic VX B18c)
thanx i also got the front and rear tie bars, i know the rear wont because it doesnt have the same mounting locations, but will the front?
Old Dec 4, 2004 | 09:28 PM
D21X's Avatar
even in a lightweight hatch, do u guys think the rear subframe will rip??? I've seen the rear subframe and it does not look very strong, but does the ripping occur because of the weight in the rear or because of the stress the rear end takes???
Old Dec 4, 2004 | 09:45 PM
TriniTech's Avatar
Default Re: type r sway bar? eg hatch? (D21X)
i've personally never seen anything like that happen...EVER.... so i mean i dunno
Old Dec 7, 2004 | 10:46 AM
null.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D21X &raquo;</TD></TR><TR><TD CLASS="quote">even in a lightweight hatch, do u guys think the rear subframe will rip??? I've seen the rear subframe and it does not look very strong, but does the ripping occur because of the weight in the rear or because of the stress the rear end takes???</TD></TR></TABLE>
it's the stress on the sway bar (rear) that makes the subframe rip. thats why they made beaks kit to reinforce the subframe.
Old Dec 7, 2004 | 10:55 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: type r sway bar? eg hatch? (EJ7COUPE)
Softer rear springs (non race) will force the sway bar to do more work. This work is offset by the subframe (it what keeps the bar in place). The ITR doesn't use the same swaybar mounting points as the EG's for a reason. It's weak. I have seen many photos of torn sub frames. You can buy the special tie bar from comptech's sway/tie combo that provides you with a solid reinforced mounting base. Contact comptech, they will sell it seperatly. Then just use some energy suspension 22mm mounting brackets, and be done. The beaks kit looks good, but I have seen one photo of a subframe still attached to th it after it had been removed from the car...
Old Dec 7, 2004 | 06:36 PM
TriniTech's Avatar
Default Re: type r sway bar? eg hatch? (94eg!)
i just want to know if i can just bolt it up and be worry free, my stock lower control arms dont have the mounting holes for the sway bar but i can get a hold of the type r lca's or ls lca's. but now i see this subframe rippin stuff, whats the beaks kit and where can i get it?
Old Dec 7, 2004 | 07:21 PM
Beatkidd's Avatar
if your car has abs then cam with a front sway bar
but no rear sway bar youll need to get gsr rear LCAs if your going to use a gsr sway bar and moutning brackets or a beaks kit
or you have to get ITR lcas to mount the type r say and i believe you have to change your shocks if you get ITR LCAs somebody correct me if im wrong
Old Dec 10, 2004 | 08:00 PM
TriniTech's Avatar
Default Re: type r sway bar? eg hatch? (Beatkidd)
i'm gonna get a beaks kit, itr lower control arms for the rear, my car doesnt have abs but i do have a front sway bar, so it should fit right?
Old Dec 11, 2004 | 09:04 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: type r sway bar? eg hatch? (VtecKills)
Can you run an itr rear bar on gsr rear lcas?
Old Dec 11, 2004 | 09:24 AM
TriniTech's Avatar
Default Re: type r sway bar? eg hatch? (litterbox)
yes you should be able to because the gsr came with a stock rear sway bar
Old Dec 11, 2004 | 09:26 AM
Street Ghost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Can you run an itr rear bar on gsr rear lcas?</TD></TR></TABLE>
Yes. Any 94-00 Integra Rear LCA will do. Or 99-00 SI if you have an EK.
Old Dec 11, 2004 | 01:03 PM
methos713's Avatar
Default Re: type r sway bar? eg hatch? (_Edge.ONE)
will suspension tech. rear sway bar fit my 95 civic si hatch? Anyone got this on their car?
Old Mar 18, 2005 | 08:08 AM
FULL throTTLe's Avatar
Default Re: type r sway bar? eg hatch? (methos713)
man i swear on my ******* 93 SI hatch, i did not see holes on my subframe to bolt up you guys should check that up, or i was just blind because it was darka nd my car is tucking all 4 wheels but you guys should check your subframe
Jugga
Suspension & Brakes
Jan 16, 2007 10:25 PM
808State
13
Mar 2, 2005 12:11 PM
(Civic_Duty)
15
Jan 20, 2005 05:27 PM
sc_92_civic_hatch
Jan 26, 2004 11:47 AM
BumpinVTEC
Nov 3, 2003 07:51 AM
